Compression question
Old Jul 26, 2007 | 08:12 PM
duneracer69's Avatar
Default Compression question
i was wondering if any body tell me what the compression is stock on a 95 ls integra motor is thanks
Old Jul 26, 2007 | 08:59 PM
Default Re: Compression question (duneracer69)
bump
Old Jul 26, 2007 | 09:07 PM
Kyle R's Avatar
Compression ratio? Or numbers from a compression test?
Old Jul 26, 2007 | 09:19 PM
Default Re: Compression question (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">Compression ratio? Or numbers from a compression test?</TD></TR></TABLE>
if you could give me both that would be awesome man thanks
Old Jul 26, 2007 | 09:33 PM
Kyle R's Avatar
Typical numbers from a compression test are around 180psi. As long as all 4 of the cylinders are around the same number, you are fine (unless all 4 are really really low). Compression ratio of a b18b out of a 95 LS is 9.2:1
Old Jul 27, 2007 | 04:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">Typical numbers from a compression test are around 180psi. As long as all 4 of the cylinders are around the same number, you are fine (unless all 4 are really really low). Compression ratio of a b18b out of a 95 LS is 9.2:1 </TD></TR></TABLE>
thanks man
snowblind7x
Apr 13, 2005 08:12 PM
Mr.Integra
Apr 22, 2004 07:56 PM
Mr.Integra
Apr 22, 2004 07:55 PM
DOHCarp
Sep 11, 2003 07:10 PM
