compression??
Old Mar 6, 2008 | 12:47 AM
nevrkno's Avatar
Default compression??
ok so im curious on what my compression should read on a compression check...like what are the numbers it should be in between???
Old Mar 6, 2008 | 02:46 AM
tartje's Avatar
Default Re: compression?? (nevrkno)
the numbers will vary from gauge to gauge, you just want to make sure the numbers are consistent across all 4, if the numbers are low, then do a leakdown test
Old Mar 6, 2008 | 06:13 AM
CW-ITR's Avatar
Default Re: compression?? (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">the numbers will vary from gauge to gauge, you just want to make sure the numbers are consistent across all 4, if the numbers are low, then do a leakdown test</TD></TR></TABLE>
Old Mar 6, 2008 | 08:32 PM
nevrkno's Avatar
Default Re: compression?? (CW-ITR)
alright thanks a lot...im good then i think lol
Old Mar 13, 2008 | 09:15 AM
Chicago_Type_R's Avatar
talking about Comp test I just did one today to see if my motor is running healthy ..first cylinder 190psi, 2#180psi, 3#200psi, 4#200psi.
So what You guys think about the numbers is it good or bad ??
Sorry for hacking in your thread.
Old Mar 13, 2008 | 08:48 PM
nevrkno's Avatar
Default Re: compression?? (Chicago_Type_R)
its cool man i think those are good numbers...but like the other guy said it verys on guages
Old Mar 13, 2008 | 09:49 PM
neo_'s Avatar
Cylinder #2 seems to be on the borderline problem side.
Old Mar 13, 2008 | 10:09 PM
00-501itrspec's Avatar
i juts did one tonight from right to left 175-125-200-260-
then again we blew my **** on the dyno also
thats a motor that have 280 across
im waiting for my buddy to post some videos , nitrous is fun
Old Mar 14, 2008 | 08:28 PM
r6toeg6's Avatar
Default Re: (00-501itrspec)
damn, 260 on #1. I have the same question, what is the compression supposed to be at?? I know they shold be equal, but a good motor should have a set number? I know its supposed to be more than 200psi.
Old Mar 16, 2008 | 07:28 AM
ITR-965's Avatar
Default Re: (r6toeg6)
I ran solid low 230's on mine with a jrsc on it. I was very impressed and surprised to see those numbers with almost 100k on it and over 30k boosted miles.
Old Mar 16, 2008 | 12:16 PM
r6toeg6's Avatar
Default Re: (ITR-965)
damn, thats nice. Question for you then, i have a buddy whos selling his ITR motor to me, he keeps it real clean, hes giving it to me cheap just to hook me up, when he got it, it was 210 across, as of right now, i think its 200 across. What do you think? Should i still get it?
Old Mar 19, 2008 | 10:30 AM
nevrkno's Avatar
which type r motor is it tho cus that will change the numbers some....jdm is 11.0:1 and usdm is 10.6:1 so what would the difference be in those 2???
Old Mar 19, 2008 | 01:07 PM
Haleiwa-Brando's Avatar
Default Re: (nevrkno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevrkno &raquo;</TD></TR><TR><TD CLASS="quote">which type r motor is it tho cus that will change the numbers some....jdm is 11.0:1 and usdm is 10.6:1 so what would the difference be in those 2???</TD></TR></TABLE>
It doesn't matter what the numbers 'should' be. It matters what they are.
Your variance per cylinder should only be 3-5%. Any thing more than that and you have a problem in the making.
If you get a low cylinder, pour a t-spoon of oil into the cylinder, and recheck. If the compression goes up, then the rings are going bad/not seated well. If the compression is still off, then you have a problem with either the head gasket or the head.
Old Mar 19, 2008 | 06:14 PM
r6toeg6's Avatar
its a JDM type r motor
Old Mar 20, 2008 | 03:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r6toeg6 &raquo;</TD></TR><TR><TD CLASS="quote">damn, 260 on #1. I have the same question, what is the compression supposed to be at?? I know they shold be equal, but a good motor should have a set number? I know its supposed to be more than 200psi.</TD></TR></TABLE>
when my motor was stock with 20k on the odo. it had 230 acrosss the board . thats what a USDM ITR runs stock .
Old Mar 22, 2008 | 06:27 PM
Fat Chick Magnet's Avatar
I had 225-225-225-225 across the board on a dry test about 4 months ago.
Old Dec 8, 2008 | 06:08 PM
bbqman's Avatar
Default fresh rebuild compression specs
I searched everywhere, but I cant find any solid info on what to expect as compression numbers after a stock, 1st oversize B18c5 rebuild.
My test before teardown yeilded 200-180-200-220. The car was about 7 mph down on top speed vs a fresh ITR on a long back straight, all things equal.
There was 100,000km on the last rebuild, but I was never satisfied from the start.
what should I expect?
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
Tad
Jun 27, 2005 12:04 AM
cu3tip
Mar 14, 2004 09:03 PM
ithrowpoop
Apr 22, 2003 04:01 PM
