compression test question
Old Apr 20, 2003 | 01:36 PM
ithrowpoop's Avatar
Default compression test question
i did a compression test on my car with 33k on the clock. are 256, 258, 259, 255 good numbers? i know there is not supposed to be a difference of 15psi per cylinder.
Old Apr 20, 2003 | 01:39 PM
VTHokie's Avatar
Default Re: compression test question (ithrowpoop)
I think the helms manual says ~20 variance. But those are some very healthy numbers. What car is that?
Old Apr 20, 2003 | 01:50 PM
ithrowpoop's Avatar
Default Re: compression test question (VTHokie)
2000 type r
Old Apr 20, 2003 | 02:48 PM
Eva01's Avatar
Look good to me.
Old Apr 20, 2003 | 02:52 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: compression test question (Eva01)
wow...looks good to me...what kind of gauge did you use?? numbers seem kinda high
Old Apr 20, 2003 | 02:56 PM
VTHokie's Avatar
Default Re: compression test question (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">wow...looks good to me...what kind of gauge did you use?? numbers seem kinda high </TD></TR></TABLE>
Yeah, i was thinking the same thing. I only got 235 across, That is one gifted motor
Old Apr 20, 2003 | 05:08 PM
ithrowpoop's Avatar
it is made by Lisle. i got it at a local auto part store. i think it was autozone or autobarn.
Old Apr 21, 2003 | 01:57 PM
Lost Motion's Avatar
Sounds a little high but agian the real test is if all the numbers are close to each other. Those number seem to be more than fine. Wouldn't expect much different considering the that the car runs strong.
Old Apr 21, 2003 | 02:12 PM
CPR's Avatar
CPR
Those numbers are crazy high! Are you sure you...
1.) Removed all the sparkplugs when doing the test
2.) Press the gas pedal all the way down while cranking the engine
3.) Crank it 5 times
Old Apr 21, 2003 | 03:44 PM
Chubz's Avatar
Default Re: compression test question (CPR)
I stop cranking when the needle stops, thats at 8 cranks. being that I have CTR pistons im well over 300 psi in every cylinder
Old Apr 21, 2003 | 05:03 PM
ithrowpoop's Avatar
Default Re: compression test question (Freakzilla)
that is what i did.
Old Apr 21, 2003 | 06:48 PM
Tuney's Avatar
great numbers!
Old Apr 21, 2003 | 08:45 PM
seanb18c1's Avatar
ummmm...
I just did mine 99GSR 83K+ miles
230 225 230 230
Nominal on a GSR is 270 minimum is 140, ITR's have higher compression than GSR's
Old Apr 22, 2003 | 03:33 PM
Chubz's Avatar
Default Re: (seanb18c1)
youll never hit 270 on a stock compression GSR 200-230
Old Apr 22, 2003 | 03:42 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Freakzilla)
there are so many variables that also go into it...
if you do it with the engine warm, you will have less piston to wall clearance, making the numbers higher as well...
the major thing is if the numbers are within 10-15% of each other...
Old Apr 22, 2003 | 04:01 PM
sneakychaos's Avatar
sometimes the difference could be the gauge used. go out and buy 2 different manufacturors comp. gauge, and I'd be willing to be they are off between 10-20 psi. I've seen this first hand.
nevrkno
Dec 8, 2008 06:08 PM
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
Chubz
Honda S2000
20
May 1, 2006 10:37 AM
fizic
10
Feb 6, 2005 12:28 PM
MechEng
Feb 11, 2002 06:15 PM
