code 21
Old Jun 23, 2008 | 09:14 AM
Fat Chick Magnet's Avatar
Default code 21
I was cruising the other day and out of no where my car CEL came on and threw code 21. I checked and it says vtec solenoid, but problem is the car is still engaging in vtec. Anyone got a clue? I reset the ecu and checked wires on dash harness and engine harness, but everything looks normal. I also reset my ecu a few times, but didn't help.
code 21
92-95 Civic
93-95 Prelude
94+ Integra VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
Old Jun 23, 2008 | 09:18 AM
walker111's Avatar
Default Re: code 21 (Fat Chick Magnet)
Put some oil in the car.
Old Jun 23, 2008 | 09:40 AM
Bradstard's Avatar
Default Re: code 21 (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Put some oil in the car.</TD></TR></TABLE>
x2
Also, pull your VTAK solenoid and make sure the screen is blocked.
While it is off, you might want to think about porting and polishing it.
Old Jun 23, 2008 | 09:41 AM
walker111's Avatar
Default Re: code 21 (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">
x2
Also, pull your VTAK solenoid and make sure the screen isn't blocked.
Old Jun 23, 2008 | 09:43 AM
jvtec95's Avatar
I've had this too since I rebuilt my head. I've replaced the vtec solenoid to see if that was the problem, but haven't run it up through vtec yet. I was getting it with full oil, too.
Anyone have any experience fixing this on their car?
I've heard that after a rebuild sometimes the solenoid has to fill with oil before it will work again, but this shouldn't be the case for your situation. Maybe an oil pressure problem?
If I remember correctly three things have to be met: 1) vtec crossover RPM 2) engine coolant up to temperature 3) oil pressure (on usdm cars)
Opie's Avatar
Someone say Vtack solenoid?
Old Jun 23, 2008 | 10:18 AM
ported vtec solenoid lol .. anyone balance theirs before?
Old Jun 23, 2008 | 10:30 AM
citrus3000psi's Avatar
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">ported vtec solenoid lol .. anyone balance theirs before? </TD></TR></TABLE>
I don't know why you guys run the solenoid at all. VTAK 24/7 yo.
Old Jun 23, 2008 | 10:38 AM
Erik95LS's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know why you guys run the solenoid at all. VTAK 24/7 yo.</TD></TR></TABLE>
I actually removed mine and replaced it with a light switch. That way I can turn off the vtack for gas conscious highway driving and then turn it on constant for hard edge track/canyon carving...
Next season I may try to install a dimmer so I can dial in the amount vtack for different situations.
Old Jun 24, 2008 | 09:16 AM
jvtec95's Avatar
Default Re: (Erik95LS)
As funny as this is, does anyone have any actual help?
Old Jun 24, 2008 | 09:18 AM
Erik95LS's Avatar
Default Re: (jvtec95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvtec95 &raquo;</TD></TR><TR><TD CLASS="quote">As funny as this is, does anyone have any actual help?</TD></TR></TABLE>
it was already said. Make sure you have enough oil in the car and make sure the screen isn't blocked by anything and also make sure there is a good seal between the solenoid and the head. Thats about all there is beyond a bad solenoid itself.
Senbonzakura
Aug 27, 2006 01:16 AM
asubennett
Apr 14, 2006 03:57 PM
gots_a_sol
Aug 4, 2004 05:32 PM
Hondasaurs
Apr 25, 2003 07:30 PM
