VTEC Common Problem
Old Aug 27, 2006 | 12:45 AM
Senbonzakura's Avatar
Default VTEC Common Problem
Is there any common problems that integras have when VTEC engage?
My check engine light went on when i engaged in vtec today. Going to check out the codes later but just wondering.
Old Aug 27, 2006 | 12:46 AM
b00sted_hatch's Avatar
Little Hercules
Default Re: VTEC Common Problem (Kyo Kusanagi)
What did it do exactly when the code came up? Be specific and I can probably help..
Old Aug 27, 2006 | 12:48 AM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
Default Re: VTEC Common Problem (b00sted_hatch)
Get the code read at autozone, that'll give us a better idea.
Old Aug 27, 2006 | 01:03 AM
Little Hercules
Just jump you Diagnostic port with a paper clip, and watch the CEL light..
Long flash = first # in the CEL code
Short flast = Second # in CEL code
Just like if it flashed like this:
long..long..short..short.. = Code 22
Thats how it reads, if you didn't know it already.. And that's probably the code you threw, which is VTEC Sileniod Malfuntion/System Malfunction. On a scanner it would probably be code P1259.. Just my guess?
Old Aug 27, 2006 | 01:14 AM
god.loves.ugly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted_hatch &raquo;</TD></TR><TR><TD CLASS="quote">Just jump you Diagnostic port with a paper clip, and watch the CEL light..
Thats how it reads, if you didn't know it already.. And that's probably the code you threw, which is VTEC Sileniod Malfuntion/System Malfunction. On a scanner it would probably be code P1259.. Just my guess? </TD></TR></TABLE>
it could be a lot of things though.... I get my knock sensor code when i hit vtec because my knock sensor isn't wired yet....
just do what he said and check the code yourself. autozone sucks.
and then you will know what the problem is
Old Aug 27, 2006 | 01:16 AM
Little Hercules
Default Re: VTEC Common Problem (God.Loves.Ugly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God.Loves.Ugly &raquo;</TD></TR><TR><TD CLASS="quote">
it could be a lot of things though.... autozone sucks.
Two VERY good points..
DarkBB4
May 7, 2007 03:06 PM
integracivic94
Aug 22, 2004 08:42 AM
AngryNerdRock
Aug 23, 2003 06:13 AM
Hondasaurs
Apr 25, 2003 07:30 PM
