check engine light....CODE 90
Old Dec 20, 2004 | 10:33 PM
integra_type-r's Avatar
Default check engine light....CODE 90
finnally found out what was the problem
Code 90 = Evaporative Emission Control System leak detected in the fuel tank area
wahts taht and how do i fix it??
has this ever happen to u guys?
help..thanks
Old Dec 24, 2004 | 06:08 AM
Dave_B's Avatar
Not exactly sure what code I got but I just had an evaporative emmisions code. It turned out to be the 2 way check valve. I got the part for 36.50 and install was free. If it's the same expect to spend around 100 or so to fix. Good luck
Old Dec 24, 2004 | 08:07 AM
NINJA's Avatar
Default Re: check engine light....CODE 90 (Integra_Type-R)
I got the same CEL at the end of the summer....
I thought it could have been due to my VAFC II install, but through some research I found it could be from many things, even something as simple as a bad gas cap.... Use the search there's some info in the archive as well as on other popular integra boards.
cheers.
Old Dec 24, 2004 | 08:12 AM
Chris F's Avatar
Default Re: check engine light....CODE 90 (NINJA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA &raquo;</TD></TR><TR><TD CLASS="quote">bad gas cap....</TD></TR></TABLE>
Could have been a loose gas cap, or a bad gas cap, or (doubt it) a loose hose on the evap canister etc. under the hood?
Try tightening the gas cap (couple of clicks) and see if it goes away in a week. If not, probably a bad gas cap, I *think* the dealer would have the tool to check if the gas cap is bad or not. Probably worth just replacing it if it doesn't go away.
Old Dec 24, 2004 | 08:19 AM
white rocket's Avatar
Default Re: check engine light....CODE 90 (Chris F)
I used to get that code like every month. I just tighened the gas cap, disconnect the battery, reconnect, then continue to drive it like it's stolen. Hasn't come on in a while though. Maybe I actually fixed something right this time.
Old Dec 24, 2004 | 09:29 AM
yeaa i knew it!!! i tried taht a couple days ago and the cel light went away =]
Thanks Chris and to all that replied
Old Dec 24, 2004 | 12:48 PM
nemesis0104's Avatar
make sure to do 3 clicks for that gas cap.....
Old Dec 24, 2004 | 02:17 PM
1Quikgsr's Avatar
Default Re: check engine light....CODE 90 (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">I used to get that code like every month. I just tighened the gas cap, disconnect the battery, reconnect, then continue to drive it like it's stolen. Hasn't come on in a while though. Maybe I actually fixed something right this time.</TD></TR></TABLE>
lmfao
numotive
Mar 30, 2006 02:24 PM
kydragger
Mar 11, 2005 09:58 PM
weana
Oct 14, 2004 08:36 AM
Aaron M
Mar 17, 2003 11:47 AM
Outsider GSR
Jan 17, 2002 07:42 PM
