Check Engine code 90
Old Oct 3, 2005 | 08:18 PM
numotive's Avatar
Default Check Engine code 90
CEL is throwing code 90 which is "90 Evaporative Emission Control System leak detected in the fuel tank area." I tried replacing my gas cap, but the code still came back. Anyone ever got this code before? Could I have a hole somewhere else in my gas tank or something?
Old Oct 3, 2005 | 11:43 PM
numotive's Avatar
Default Re: Check Engine code 90 (numotive)
bump
Old Oct 4, 2005 | 01:10 AM
kchungb17a's Avatar
did you install an amp lately? Say below the drivers seat or in the back somewhere?
Old Oct 4, 2005 | 06:42 AM
..::91TEG-G2::..'s Avatar
Default Re: Check Engine code 90 (kchungb17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">did you install an amp lately? Say below the drivers seat or in the back somewhere? </TD></TR></TABLE>
what would this do? because i have a "brain" for my deck under my seat that was mounted with screws by circuit city..
Old Oct 4, 2005 | 11:36 AM
91IntegraX's Avatar
could be fuel pump or lines
Old Oct 4, 2005 | 02:43 PM
R6Boy69's Avatar
yeah what does this have to do with anything? I had this same problem with a 99 civic coupe i would just have to keep reseting the ecu and it would go away for awhile, then come back. I also tried to replace the gas cap like the dealer said and no luck...
Old Oct 4, 2005 | 04:43 PM
numotive's Avatar
Default Re: Check Engine code 90 (R6)
no haven't installed any amps recently. when i reset the ecu, it just throws the code again. i tried replacing my gas cap, still comes back in like a day after i reset ecu
Old Oct 4, 2005 | 05:00 PM
kchungb17a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah what does this have to do with anything? I had this same problem with a 99 civic coupe i would just have to keep reseting the ecu and it would go away for awhile, then come back. I also tried to replace the gas cap like the dealer said and no luck...</TD></TR></TABLE>
On Integras and Civics (most cars, actually) the fuel lines run underneath the driver's seat. You get the wrong installer that doesn't know jack about cars and starts drilling holes though your floorboard and eventually, he's going to hit something, like an evaporative fuel line (I've seen it) which will throw your code 90. Or in the back, a bad installer can drill right into the fuel tank (seen that too).
numotive, since you say you haven't had one installed recently then you may just have a leak somewhere in one of those lines that runs from your fuel tank and back. Most shops have a diagnostic tool for this that blows smoke into the lines at low pressure, allowing the leak to be visible to the technician. You can try to do a visual check yourself if you want to get under there, but if the damaged isn't obvious, it may be difficult to find the leak.
Old Oct 4, 2005 | 05:29 PM
91IntegraX's Avatar
just get a lighter and waive it around under there....then ull find a fuel leak no prob JK dont do that
Old Oct 5, 2005 | 06:15 PM
numotive's Avatar
Default Re: Check Engine code 90 (91IntegraX)
i guess i'll have to take it in to a shop then... weak sauce
Old Mar 26, 2006 | 07:43 AM
iwantturbo's Avatar
im having this problem rite now... CEL is throwing a "Evaporative Emission Control System leak detected in the fuel tank area" code. only time i messed with the gas was a few weeks ago when i put some chevron techron fuel system cleaner. the car seems to run and drive fine, but the CEL is bothering me. any help?
Modified by iwantvtec at 10:03 PM 3/27/2006
Old Mar 27, 2006 | 09:04 PM
iwantturbo's Avatar
Default Re: Check Engine code 90 (iwantvtec)
bump
Old Mar 28, 2006 | 09:42 AM
phildo1219's Avatar
bump cuz im having the same problem with my civic
Old Mar 28, 2006 | 09:23 PM
iwantturbo's Avatar
Default Re: (phildo1219)
bump
Old Mar 30, 2006 | 02:24 PM
b18c4dr's Avatar
Default Re: (iwantvtec)
96 gsr throwing 92 cell same issues try changing evap sensor mayby this will work for you didnt work for me
kydragger
Mar 11, 2005 09:58 PM
integra_type-r
Dec 24, 2004 02:17 PM
weana
Oct 14, 2004 08:36 AM
R6Boy69
Nov 5, 2003 07:50 PM
People_Mover
Feb 12, 2003 12:29 PM
