Code 90
Old Jan 17, 2002 | 06:56 PM
Outsider GSR's Avatar
Default Code 90
Last night I threw a check engine light. Well I checked it and its code 90, Evaporative Emission Control System leak detected in the fuel tank area. Well my question is, is this dangerous? Does that mean I have a leak in my fuel tank. I don't want to be driving and then boom!!! Any input would be appreciated...
Old Jan 17, 2002 | 07:16 PM
neo1z's Avatar
Default Re: Code 90 (Outsider GSR)
well 90 could mean a whole lot of diff stuff - im actually throwin 90 right now also. first time i had a faulty charcoal canister -- but id check ur gas cap, if its loose or not all the way on then u can throw a light. also, if you overfilled your tank id u could set it off as well. gas cap is best bet - take it off put it on and reset the ecu.
otherwise id take it up to acura and get them to check it out.
Old Jan 17, 2002 | 07:42 PM
Chris's Avatar
AAHAHAHAHAH!! Please go make sure you GAS CAP is all the way on (more that 3 "clicks"). Ive seen it before...its a common problem.
londonsupra
Jul 7, 2006 05:30 PM
Civic Racer X 7
Jun 27, 2005 01:08 PM
kydragger
Mar 11, 2005 09:58 PM
Aaron M
Mar 17, 2003 11:47 AM
neo1z
Oct 30, 2001 05:57 AM
