Bearing sizes????
Trying to seek some information for a friend...
Can anybody shed some light on sizes for the main & rod bearings in reference to the colors or numbers & letters???
Thanks,
Chris
Thanks,
Chris
MAIN:
Letters are on the block, numbers are on the crank, put the two together to get color code
ROD:
Letters are on the crank, numbers are on the rods, same process as above
ROD:
Thanks, sgT
However, I guess that part he knew already. His question is this...
For a car with custom rods/crank, how do you determine the actual bearing sizes in reference to color? In building race motors or other custom applications, apparently there are times when these letters and numbers are no longer available for reference!?!?!?
I hope I'm asking this clearly.
Chris
Chris
If i have 3 ITR cranks and all are labeled X then i will have the same bearing color.
Cranks dont usually wear down unless a bearing is spun. It takes quite a bit
to even begin to wear down a journal.
turqoise?
That color doesnt exist.
Available colors are: Red,Pink,Yellow, Green, Brown, Black, Blue
and i thought you would have got the sarcasm
<--got the sarcasm, and likes cammo himself
Thanks for all of the help!
What are the sizes for each of the bearing colors you mentioned above? In particular, the yellow, green, brown and black????
Chris
Chris
Plastigauge. i just went through this. And no....THERE IS NO generic assumptions
