VTEC?
Old Jun 27, 2005 | 08:18 PM
Lauj87's Avatar
Default VTEC?
alright guys..i need some help here.. for some reason the Vtec On my GSR isn't opening....i can still bring it up to 8000 rpms but then at 6k where vtecs suppose to hit...nothing happens....funny thing is some times it does open.
Old Jun 27, 2005 | 08:21 PM
honda011's Avatar
Default Re: VTEC? (Lauj87)
at 6k is where ur secondaries open up, ur vtec opens at like 4400 rpms, also hows ur oil vtec doesn't pop if u have low oil, also do u have any cel's?
Old Jun 27, 2005 | 08:28 PM
Preferio's Avatar
Default Re: VTEC? (honda011)
If your oil is low, then it could cause it not to engage... My friend had that problem...
Old Jun 27, 2005 | 09:34 PM
Lauj87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">alright guys..i need some help here.. for some reason the Vtec On my GSR isn't opening....i can still bring it up to 8000 rpms but then at 6k where vtecs suppose to hit...nothing happens....funny thing is some times it does open. </TD></TR></TABLE>
i just did a Oil change last week soo oil should be good...soo vtec opens at 4400 on a stock ecu? but when the secondary opens i should hear the engine scream alot louder...and it dosnt..its just the same tone all the way to redline....and my bros civic with a GSR screams like crazy at 6k..it pulls alot harder too.
Old Jun 27, 2005 | 09:54 PM
honda011's Avatar
well a civic is lighter so its going to pull harder, also wut mods do u have?? with a stock exhaust and intake u really can't hear vtec..
Old Jun 28, 2005 | 06:08 AM
7k rdlne's Avatar
vtec engages at 4400 rpm with the stock gsr ecu, secondaries open at about 5800 rpm with the stock gsr ecu, if you dont have an intake or exhaust youll really have to listen to hear vtec.
Old Jun 28, 2005 | 06:50 AM
Racermech's Avatar
Default Re: VTEC? (7k rdlne)
are you just reving it, or are you dricing and going to 8000?? Also the car has to be warm for vtec to work.
Old Jun 28, 2005 | 07:49 AM
. a d a m's Avatar
Default Re: VTEC? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">are you just reving it, or are you dricing and going to 8000?? Also the car has to be warm for vtec to work.</TD></TR></TABLE>
Yeah, if you're only revving it, then its not coming on because you have to be moving for VTEC to work.
Old Jun 28, 2005 | 11:46 AM
Lauj87's Avatar
well i found my problem...i had a vacume leak soo my secondary throttle wouldnt open..fixed it now works perfect....thanks for all the help guys!
tigasin
Nov 14, 2008 11:58 PM
JSpekBB4
Oct 30, 2007 10:23 PM
vietnogi
Apr 13, 2005 10:01 PM
fabe85
Nov 27, 2004 11:30 PM
charms119
Jan 3, 2003 02:04 PM
