Need Help! V-tec Problem
Old Jan 9, 2003 | 01:47 PM
DocV's Avatar
Default Need Help! V-tec Problem
Hey H-T,
I have a 2k1 GS-R and today my V-tec did not kick in at all. I check the oil and it's not low, so what else could be the problem. The car only has 20k on it and the mods are I/h/e w/ a test pipe. Any ideas? Thanks
Old Jan 9, 2003 | 02:39 PM
threatcon13's Avatar
New User
Default Re: Need Help! V-tec Problem (VtecNit2k1)
temperature..but since u said it did not kick in all day im assuming thats not it. maybe your solenoid went bad. take it into acura...it will be covered under warranty. regardless of i/h/e/tp. (does not affect any of the vtec components.)
Old Jan 9, 2003 | 05:04 PM
DocV's Avatar
Thats good to hear. I was afraid to bring to the dealership. Hopefully it works out. But what would make the solenoid die out at 20k?
Old Jan 9, 2003 | 05:18 PM
djtony5's Avatar
Well first of all how do you know that your vtec is not engaging?
Old Jan 9, 2003 | 05:20 PM
DocV's Avatar
Default Re: Need Help! V-tec Problem (djtony5)
You can tell b/c there is not a change over in sound at 4,500 or 6k. But the call doesn't pull like it usually does in that rpm range.
Old Jan 9, 2003 | 05:25 PM
EL Vap133's Avatar
What does it redline at now that vtec doesn't kick in?
Old Jan 9, 2003 | 05:27 PM
DocV's Avatar
Default Re: Need Help! V-tec Problem (Vap133)
The redline is the same but theys no change over, but it's hard to get it up to redline b/c they's no power.
Old Jan 9, 2003 | 05:41 PM
JeremyL's Avatar
Default Re: Need Help! V-tec Problem (zetarider)
if youre not the original owner it "might" not be covered or they may just give you **** and try to tell you its not, if they do ask to see a specific policy which states such...also if the car has a salvage title it definitely wont be covered
they also will try to give you **** about the mods you have
Old Jan 10, 2003 | 06:43 AM
DocV's Avatar
Default Re: Need Help! V-tec Problem (JeremyL)
no i'm the original owner. The check engine light is on but it's b/c of the test pipe.
Old Jan 10, 2003 | 07:23 AM
New User
why wouldn't it be covered? regardless of first or second owner, that does not matter. trying to tell you "it is not covered" is illegal. if your seat is broken and you have changed out your intake, the fact that you changed your intake has no bearing on the fact that your seat is broken. i don't know what would cause a solenoid to go bad at 20k miles, but shxt, i had my tranny on my bmw replaced at 50k for free, because it had problems. so i would definitely take it to the dealer. maybe replace the test pipe w/ your stock cat before you take it in.
Old Jan 10, 2003 | 11:54 AM
EL Vap133's Avatar
If VTEC doesn't kick in, I don't think it will let you get all the way up to Redline.....
Old Jan 10, 2003 | 12:18 PM
New User
false.
Old Jan 10, 2003 | 02:56 PM
EL Vap133's Avatar
Default Re: Need Help! V-tec Problem (ALLMOTORDC2)
If VTEC doesn't kick in, I don't think it will let you get all the way up to Redline..... false.
Ok, I guess it's only on my 1st gen B16a......
Old Jan 10, 2003 | 03:23 PM
SMZ GSR's Avatar
pull out your spark plug wires and check for any oil leaking in.
when i got my timing belt done at the dealer they didn't replace one of the rubber grommets and it caused cylinder full of oil. The same day i caught it, my VTEC wasn't kickin in either. Pulled off the valve cover, replaced all grommets and valve cover gasket, dried up the cylinder. and when i took it to the freeway after warming up, gunned it. it was like night and day.
Old Jan 10, 2003 | 05:46 PM
DocV's Avatar
Default Re: Need Help! V-tec Problem (SMZ GSR)
Don't worry it was nothing major it was my Vechicle speed sensor. It got some salt and **** from Sunday's snow storm in DE. My car is so low I guess that it got caught up in there. Thanks for you guys advice though.
Old Jan 10, 2003 | 06:58 PM
neo1z's Avatar
oh i was going to say...definitely take off the test pipe before you go to the dealer...but hey, you got it fixed.
willem
16
Feb 19, 2012 04:07 AM
210jdmgsr
Jul 30, 2007 06:27 PM
AamirCWITR
Oct 17, 2003 09:39 AM
BlckSI
Aug 29, 2003 06:48 PM
DocV
Jan 10, 2003 05:52 PM
