Vtec
Old Nov 6, 2005 | 10:29 AM
ricebegone13's Avatar
Default Vtec
My Vtec isnt coming in right. It comes in fine in a straight line but when i go into a turn Vtec falls out or wont come in if it isnt in when i enter the turn.
What is the problem?
Old Nov 6, 2005 | 10:30 AM
vice's Avatar
check your oil level/pressure
Old Nov 6, 2005 | 10:42 AM
Sleepy_Red_hatch's Avatar
Default Re: (vice)
when you turn, do you go lower then 5200 rpm?
Old Nov 6, 2005 | 11:55 AM
projectTeG's Avatar
Default Re: Vtec (ricebegone13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricebegone13 &raquo;</TD></TR><TR><TD CLASS="quote">My Vtec isnt coming in right. It comes in fine in a straight line but when i go into a turn Vtec falls out or wont come in if it isnt in when i enter the turn.
What is the problem?</TD></TR></TABLE>
check you oil....also in the turn stay above 4800rpms.
Old Nov 7, 2005 | 07:52 AM
Default Re: Vtec (projectTeG)
I do it was my oil I had it changed and it comes in fine now
Old Nov 7, 2005 | 07:57 AM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricebegone13 &raquo;</TD></TR><TR><TD CLASS="quote">I do it was my oil I had it changed and it comes in fine now </TD></TR></TABLE>
You were starving you engine from oil! This is not a good thing, especially in VTEC. I would check your oil more often, B-Series VTEC motors love to eat oil.
Old Nov 8, 2005 | 02:19 AM
GSRVTEC1's Avatar
Default Re: Vtec (98 Spec R)
so you saying when you turn you're still at high rpm ? damm are you looking forward for an accident?
Old Nov 8, 2005 | 09:21 AM
BlackDAy's Avatar
Default Re: Vtec (GSRVTEC1)
"damn this weak *** V-TACk!
....i need turboz....straight from Honda."
Old Nov 14, 2005 | 02:14 PM
IntegraJdmb18c1's Avatar
checking oil is serious conditon in B series motors two of my friends have spun a bearing because of low oil one in a GSR the other in a b16 all motor not a good sound or money saving situation to put yourself in
Old Nov 14, 2005 | 02:36 PM
1997GS-R's Avatar
engine+enough oil=good good=vtec=better
Old Nov 14, 2005 | 06:54 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: (1997GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1997GS-R &raquo;</TD></TR><TR><TD CLASS="quote">engine+enough oil=good good=vtec=better </TD></TR></TABLE>
nuff said
Old Nov 14, 2005 | 07:01 PM
scottishdave's Avatar
Default Re: (ohsnapzafingcu)
ALWAYS check your oil man. Every B engine i have had old and new has ate oil up. Check it when the car is cold like after it hasnt ran for atleast 45 minutes so that the oil has time to settle into the oil pan. That lets you get an accurate idea of how much oil you have, and do this like every 5 days atleast. I do every day but im ****. I also change my oil every 2000.
egmatt93
Dec 5, 2006 08:29 PM
Franken Hatch
16
Oct 3, 2006 07:42 PM
jikespingleton
Jul 24, 2006 02:21 PM
9000rpms
May 15, 2006 02:26 PM
inzaneN1
Feb 2, 2004 09:24 PM
