golden eagles vtec conversion
Old Dec 12, 2008 | 08:20 PM
jimburt3rd's Avatar
Default golden eagles vtec conversion
I just bought a 1994 Acura Integra LS. I got it with an intake and an exhaust. Im trying to get the golden eagle vtec conversion kit. just wondering? 1 if its worth it? 2 what parts should i get with it or do i need any so my engine can handle it? and 3 how much of a difference will it make? And any advice on some nice part that you would recommend? thanks!! i have also been reading that stuff doesnt match up right and oil leaks is this true. as much info would be helpfull and if someone has actually done this conversion please let me know how it went.
Old Dec 12, 2008 | 09:23 PM
stevenDAtegra's Avatar
The golden eagle LS VTEC kit doesn't actually give you vtec. It just let's you put a VTEC cylinder head onto your non- vtec LS block. The build does give you a lot of power, but takes a good sum of money and patience. Here is a link on how to do it.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
The golden eagle kit is what you need as well as
VTEC cylinder head
ARP Rod Bolts
Shotpeened LS rods
GSR Headstuds
Better pistons since the LS are only good for turbo(optional)
Knock Sensor(unless you get an P28 ECU plus a jumper harness)
Wiring for vtec
The list goes on with other smaller items listed in the thread I linked
Most of them now don't have oil leaks since kits are pretty good for it now. As long as you get a VTEC distributor instead of using the LS one and put the new oil lines on right, the engine shouldn't leak oil.
Old Dec 19, 2008 | 08:31 AM
barnie's Avatar
i had the same exact question
Old Dec 19, 2008 | 09:59 AM
jimburt3rd's Avatar
well if you get the conversion or any good upgrades that you liked let me know about it
Old Dec 19, 2008 | 10:49 AM
steveo135's Avatar
Check the FAQ at the top of the integra forum... lots of useful information about LS/V
crkelly
Jan 20, 2010 11:52 AM
CSSMiketsi
May 16, 2008 09:26 AM
modifyORdie
Jan 3, 2006 02:31 PM
integrater
Aug 2, 2005 08:57 PM
peenut4head
Sep 29, 2004 07:31 PM
