CEL: code 45
Old Sep 4, 2003 | 09:15 PM
Black R's Avatar
25 Year Member
Default CEL: code 45
"code 45: System Too Lean or Too Rich malfunction in the fuel monitoring systems"
wtf? I only have i/h/e and test pipe..... What to check?
Old Sep 4, 2003 | 09:22 PM
Dan GSR's Avatar
Default Re: CEL: code 45 (Black R)
my guess....
the O2 sensor in the test pipe is bugging out.....not reading correctly
Old Sep 4, 2003 | 09:35 PM
Ferrell's Avatar
Default Re: CEL: code 45 (Dan GSR)
Primary HO2S?
MAP sensor?
Exhaust leak?
Contaminated fuel?
Valve clearance?
Old Sep 4, 2003 | 11:14 PM
GSRdriver's Avatar
I threw that code and I needed new rings.
Old Sep 5, 2003 | 07:35 AM
98cwitr's Avatar
Default Re: CEL: code 45 (GSRdriver)
its the test pipe. wrap your o2 sensor in tin foil should fix the problem
Old Sep 5, 2003 | 04:15 PM
Black R's Avatar
25 Year Member
Default Re: CEL: code 45 (98cwitr)
.....2nd o2 sensor is zip tied to the front swaybar and wrapped in tin foil.
Now bad rings, I could believe..... why would it throw that particular code though?
Old Sep 5, 2003 | 06:57 PM
tvrsir's Avatar
do you have an o2 simulator. this goes in place of the secondary. i would think that code only comes on for the primary o2 what mods. usually higher or low fuel pressure will set this code
or you have a bad o2 primary
Old Sep 5, 2003 | 08:33 PM
b19coupe's Avatar
All things being equal, it is usually a bad primary HO2S.
Old Sep 5, 2003 | 09:37 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: CEL: code 45 (b19coupe)
I get the same code and I am stumped! I replaced my secondary o2 sensor with a Bosch universal sensor. Maybe it's that one?
Old Sep 6, 2003 | 06:19 AM
Black R's Avatar
25 Year Member
.....why are you guys saying primary o2 now?
Old Sep 6, 2003 | 12:56 PM
b19coupe's Avatar
The secondary HO2S is for checking catalyst function-it will give codes 63,65, and 67. The ECU uses the primary O2 for fuel trim-my experience has been code #45= bad primary HO2S.
Old Sep 6, 2003 | 05:28 PM
Gee3's Avatar
Does any know of a cheap place to get o2 sensors or does anyone have a couple primary o2 sensors for sale for cheap for Black R and I?
Thanks!
Old Sep 7, 2003 | 03:46 PM
Black R's Avatar
25 Year Member
..... that's definitely odd. I have an extra primary o2 sensor, so I'll install that and reset. If that code comes back, then I can rule it out.....
Old Sep 7, 2003 | 04:26 PM
Back in Black's Avatar
Rather OG
Default Re: CEL: code 45 (tvrsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrsir &raquo;</TD></TR><TR><TD CLASS="quote">usually higher or low fuel pressure will set this code
Old Sep 7, 2003 | 04:53 PM
Black R's Avatar
25 Year Member
Default Re: CEL: code 45 (Jason Franza)
.....stock fuel pressure regulator on my car. NO vafc.
Old Sep 7, 2003 | 04:58 PM
Rather OG
Hrm...
Just plugging the fact that I did get a 45 after an AEM fpr install.
Old Sep 7, 2003 | 05:28 PM
MugenizedR's Avatar
You need a fuel pressure regulator and get more fuel.
Old Sep 7, 2003 | 07:25 PM
Gee3's Avatar
Black R - keep me updated on the code. Hopefully you don't get it so I can swap out o2 sensors also.
I have an fpr and I had the fuel too high so adjusted it to stock levels but still got a code 45. I'm guessing I fouled up the o2 sensor. I'm hoping that's all it is.
Thanks!
Gary
Old Feb 18, 2004 | 06:57 PM
Black R's Avatar
25 Year Member
Default Re: CEL: code 45 (Gee3)
.....I haven't touched the car. I reset the ecu and it came back and I just left it.
Car is running pig rich and bumper gets covered in soot. *shrug*
Old Feb 18, 2004 | 07:01 PM
RTW DC2R's Avatar
could the sensor be shot from running so rich?
Old Jun 17, 2004 | 12:52 AM
alfaaay's Avatar
Default Re: (RTW DC2)
Sorry to bump such an old thread, but I'm getting the same code in conjunction with a rougher, lower idle and some hesitation/bogging. Did you ever fix the problem? I haven't done a new primary O2 yet..
Old Jun 20, 2004 | 02:17 PM
juniordc2's Avatar
i had that code before on my GSR, it was a malfunction of the o2 sensor. unplug it and check the resistance.. if someone has a helms, they can thell you the specifications.. mine was off spec, so i just bought a new o2 sensor and it was fixed, along with better performance and gas mileage than before.
i hope this helps.
Old Jul 13, 2004 | 07:01 PM
Black R's Avatar
25 Year Member
Default Re: CEL: code 45 (dc2gsr94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2gsr94 &raquo;</TD></TR><TR><TD CLASS="quote">i had that code before on my GSR, it was a malfunction of the o2 sensor. unplug it and check the resistance.. if someone has a helms, they can thell you the specifications.. mine was off spec, so i just bought a new o2 sensor and it was fixed, along with better performance and gas mileage than before.
i hope this helps. </TD></TR></TABLE>
I swapped my primary and secondary o2 sensors as a test (since their functionally the same except for the rubber grommet thingy). I also used the o2 sensor fooler resistor trick for the now secondary sensor.
It worked! I got 250 miles out of the next tank of gas, then 280 out of the next tank after that, and a little over 300 out of this last one! Mixed driving, with higher mpg on the hwy. I must add that this is with the AC on full blast and toting around a project tranny, intercooler, miscellaneous tools + floor jack, and full set of wheels in the trunk area.
I am now getting a code 63 (it popped up after about 170 miles of my test) - which is secondary sensor...
I guess that sensor really was bad after all. Thanks H-T!!!
I wasn't worried about replacing that sensor since it doesn't affect anything but the CEL...
Modified by Black R at 3:58 PM 7/17/2004
Spug
May 26, 2012 12:15 AM
SpoolinEK9
Dec 13, 2010 05:24 PM
s14hybrid
Nov 24, 2004 05:16 AM
EG2 SiR
Mar 4, 2004 10:35 AM
tub_sephiroth
Jun 11, 2003 02:21 PM
