Tranny issues
Old Mar 19, 2009 | 08:29 PM
MD-Type-R's Avatar
Default Tranny issues
Hey,
I have a 98 jdm type r motor and trans. I am just finding time to get around to working on my car again after a failed clutch/fw install.
Originally my clutch went out when I was driving. In order to get home I forced it into first gear. I have since replaced my clutch and flywheel and slave cylinder with competition clutch products.
After reinstalling the transmission and bleeding the clutch I can not get into any gear. The shifter sits far forward ( and i have checked to make sure that it is not backwards) and even if i manage to get into a "top" gear such as 1,3,5 it seems very sloppy. I can not tell if it is in gear or in neutral. Also if I put it in a "bottom" gear it sits like it should be in neutral. I have tried 3 sets of linkage, oem, avid, and oem all with the same results.
Its driving me nuts and I really would appreciate some help. Any thoughts?
Old Mar 19, 2009 | 11:12 PM
vietnamezerice's Avatar
Default Re: Tranny issues
can you go into detail when you "forced it in first gear?"
Old Mar 19, 2009 | 11:17 PM
MD-Type-R's Avatar
well i would push the clutch in in order to shift but it was not engaging, so i pretty much shifted into first without any clutch by just revving and forcing into first lol.. i am assuming that i might have bent a shift fork
MD-Type-R
Transmission & Drivetrain
Mar 23, 2009 01:09 PM
JDM Like Whoa
Dec 11, 2006 02:30 PM
B18cteg
Jul 3, 2003 10:18 AM
DefiantGSR
Jan 30, 2003 09:34 AM
crxaddikt
16
Apr 4, 2002 05:25 AM
