Transmission Problems.
Old Dec 10, 2006 | 04:30 PM
JDM Like Whoa's Avatar
Default Transmission Problems.
I am having some problems with my Transmission. I was wondering if you guys could help me out. Motor and Tranny is a JDM 98+Spec B18C with bolt ons. Stock Clutch/Flywheel/Trans.
At higher speeds, and sometimes lower ones, my car will grind going into 5th gear. Normally driving it doesnt do it half as often. No other gear does this, only 5th. Still shift smooth other than the grind. Think it could be the syncro? Maybe Needs new Clutch? Thanks in advance!
Old Dec 10, 2006 | 06:02 PM
GO-FIGHT-KILL's Avatar
Hard to tell without driving it... But often times, the fifth gear grind is from a worn clutch. I've encountered the fifth gear grind twice, and every time, a new clutch has taken care of it.
If someone managed to screw up a fifth gear syncro, they must enjoy driving their car very fast, haha.
Old Dec 10, 2006 | 06:04 PM
totsie7944's Avatar
Default Re: Transmission Problems. (ImportRacr05)
it could be either man.... I would guess you caneither drive it until something goes...or just take a look at the clutch and go from there. good luck
Old Dec 10, 2006 | 06:11 PM
The OEM clutch in it is VERY worn and slips bad somtimes. Not all the time. But makes no sense why it would do it in only 5th gear. I dunno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">it could be either man.... I would guess you caneither drive it until something goes...or just take a look at the clutch and go from there. good luck</TD></TR></TABLE>
^ I agree.
Old Dec 10, 2006 | 07:08 PM
ninor's Avatar
check your tire pressure up front, on tranny with LSD if you have rotational difference between left and right wheel, you will bend the shift fork, and it starts with 5th...
If your front tires are the same diameter and pressure, than this does not apply to you...
Old Dec 10, 2006 | 07:33 PM
Thanks man. I will check that first thing in the morning.
Old Dec 11, 2006 | 02:30 PM
Tire pressure is the same.
Well, The tranny is coming out of the car and going to King asap. Cant figure it out.
1hgej1
Mar 30, 2009 09:55 AM
MD-Type-R
Mar 19, 2009 11:17 PM
4everVtec
Mar 9, 2007 12:23 AM
KekahaB18
May 15, 2005 09:17 PM
crxaddikt
16
Apr 4, 2002 05:25 AM
