prob: my clutch or tranny?
Old Jan 28, 2003 | 08:42 PM
DefiantGSR's Avatar
Default prob: my clutch or tranny?
I need help guys, i dont kno wat happened. Recently my 4th gear started to grind alot, even when i slowly engage it and press in the clutch then shift to the gear. Then jus tonite i was driving and my whole car stopped, jolted and stalled, going like 20mph. Its stuck in 3rd or 4th gear now and i cant get it out. I can move the stick (shifter) but the gear wont go out. I cant put it to 1st, 2nd, or reverse. I had to rev it high and slowly crawl the car home like 1 min away. I dunno wats wrong, did i blow my transmission? or is it my clutch. please help, im a college student low on funds and i need my car as my transportation.
Old Jan 29, 2003 | 07:41 AM
stupidfast's Avatar
Default Re: prob: my clutch or tranny? (DefiantGSR)
Clutch Master Cylinder is my quess.. Happened to me too.. $90 to replace.
Old Jan 29, 2003 | 09:20 AM
chevyalltheway's Avatar
sonds like the syncros in the trans failed. especially if you cant get it out of gear.
Old Jan 29, 2003 | 04:36 PM
DefiantGSR's Avatar
Default Re: prob: my clutch or tranny? (chevyalltheway)
c'mon guys..i need more thoughts on this. thanks a lot
Old Jan 29, 2003 | 10:03 PM
DefiantGSR's Avatar
ttt
Old Jan 29, 2003 | 10:53 PM
Volcom's Avatar
I had a piece of my clutch disc break off and get stuck in another place on the clutch disc. So, basically that little piece was keeping the clutch from engaging and disengaging. It could be the clutch.
Old Jan 29, 2003 | 10:59 PM
turbohonda's Avatar
Default Re: prob: my clutch or tranny? (Volcom)
If you cant get it out of gear then it is definetly not the clutch, even if the clutch didn't disengage it still would come out of gear. If the syncros went bad they will not stick it in gear, at least on a b series tranny. My best guess would by you broke the shift rod selector or shift fork in the tranny and now the tranny doesn't respond to you moving the shifter in the car. You may have broken a piece off and it got jammed in one of the gears and maid your car jolt and stall.IMO
It is easily fixable if you know what you are doing and you didn't chip any of the gears when it stalled.
[Modified by turbohonda, 12:01 AM 1/30/2003]
Old Jan 30, 2003 | 12:21 AM
Volcom's Avatar
Default Re: prob: my clutch or tranny? (turbohonda)
If you cant get it out of gear then it is definetly not the clutch, even if the clutch didn't disengage it still would come out of gear. [Modified by turbohonda, 12:01 AM 1/30/2003]
Not true, it just happened to me. The only time I could get it out of gear is when I would turn the car off and put it in first gear. I would drive in 1st and try to shift to second. I couldn't ever get the car out of first and into second. If the clutch wasn't fully disengaging, the car wouldn't come out of gear and the same way with it not fully engaging. Sometimes, the car would roll forward in 1st gear like an automatic because the clutch wasn't fully disengaging.
Old Jan 30, 2003 | 12:34 AM
turbohonda's Avatar
I think part of what you said is true but I will guarantee that if you are driving down the road in a completely normal integra (any manual tranny car),you can let your foot off of the gas and you can pull it out of gear without ever touching the clutch. This isn't to good for the tranny but it is possible to do. I don't know your situation completely, and that may have happened to you, but that is not what normally happens. Besides the clutch wouldn't make the car jolt and stall unless the pressure plate or flywheel was coming off and came in contact with the tranny.
Old Jan 30, 2003 | 06:33 AM
djtony5's Avatar
Your problem is not the tranny but is in the clutch. I guarantee you that part of your clutch broke off and jam somewhere. Same problem happen to me earlier.
Old Jan 30, 2003 | 08:36 AM
Volcom's Avatar
Default Re: prob: my clutch or tranny? (djtony5)
Same thing with me. All my flywheel bolts were wore down from that little piece rubbing them. I guess that's why I had major clutch chatter also.
Old Jan 30, 2003 | 09:34 AM
RacistRobot's Avatar
its your clutch.
Bizzle5OH3
Transmission & Drivetrain
May 13, 2011 03:05 PM
new_climber
Feb 19, 2011 02:25 PM
PrettyFastRide
13
Jul 13, 2006 06:30 AM
green98civic
13
Jun 28, 2003 10:13 AM
crxaddikt
16
Apr 4, 2002 05:25 AM
