Prelude Calipers/Rotors on Teg
Old Apr 15, 2002 | 04:17 AM
teger's Avatar
Default Prelude Calipers/Rotors on Teg
Howa hard is it to fit 93 Prelude (VTEC) Calipers/Rotors to a 94 GSR Integra. I've heard it's pretty much a strait bolt on, except you have to add some washers or something? to get the calipers aligned up right? This should give me a Type R brakeing system, right?
Old Apr 15, 2002 | 07:04 AM
bps2799's Avatar
Default Re: Prelude Calipers/Rotors on Teg (teger)
Need to machine the mounting bracket. I think what you want, though are 96+ prelude VTEC calipers.
Old Apr 15, 2002 | 07:52 AM
Ausmith's Avatar
Default Re: Prelude Calipers/Rotors on Teg (bps2799)
What about a 4g Prelude Si Non Vtec (92-96) caliper.... Are they the same or different?
Old Apr 15, 2002 | 10:27 AM
bps2799's Avatar
Default Re: Prelude Calipers/Rotors on Teg (Ausmith)
I don't keep track of all the caliper changes.
Ask Brian from FastBrakes for a more definitive answer..
Old Apr 15, 2002 | 11:19 AM
aklucsarits's Avatar
New User
93-96 Prelude VTEC front rotors are 11.1". The 92-96 Prelude Si front rotors are only 10.2". The rear rotors are 10.2" on both.
But the rotors are not going to fit an Integra anyway... The 92-96 Prelude is 4x114 bolt pattern like the Accord. The 'Teg bolt pattern is 4x100...
Andrew
Old Apr 15, 2002 | 01:09 PM
Ausmith's Avatar
Default Re: Prelude Calipers/Rotors on Teg (aklucsarits)
See this post.
https://honda-tech.com/zerothread?id=164984
Old Apr 15, 2002 | 01:19 PM
New User
I was talking only about the Prelude rotors - which the original poster was asking about.
Andrew
Old Apr 15, 2002 | 05:03 PM
Allstar's Avatar
New User
I have this exact combo on my civic. Have the rotors redrilled to 4x100 at a machine shop and that is all the fabrication you need. Type r calipers are the same as accord wagon calipers so just buy which ever is cheaper at your local junkyard.
The calipers fit the rotors fine, no fabrication required,
Old Apr 16, 2002 | 06:07 AM
teger's Avatar
Default Re: Prelude Calipers/Rotors on Teg (2.2 guy)
what is the exact model Accord/Prelude that has the 11.1" Rotors and type R size Calipers?
Also, are the SI calipers the same as the calipers that fit the 11.1" Rotors?
Old Apr 16, 2002 | 07:00 AM
Ausmith's Avatar
Prelude VTEC calipers/rotors are the same as Type R.
Accord Wagon Calipers... not sure what year.
Prelude Si calipers are not the same as the Type R calipers
Old Apr 16, 2002 | 07:16 AM
bps2799's Avatar
Or '98 -'02 Accord V-6 calipers, which need no machining of the bracket at the mounting point, but will need material removed from those places on the inside that are proximal to the rotor for the sake of clearance.
Like I said earlier, check w/ Brian at FastBrakes. Not all cars need the same amount of material removed. Some rotors (e.g., Stoptech) will clear a caliper w/ no modification, while others won't. Relying on the anecdotal posts here will get you in trouble b/c some combinations won't work together. You need a clear vision of what you want to do before buying parts.
Old Apr 16, 2002 | 07:17 AM
Greyout's Avatar
you should use the acura legend GS '95-'96 two-piston calipers. They bolt right up to the prelude.
Old Apr 16, 2002 | 09:33 AM
TypeSH's Avatar
Default Re: Prelude Calipers/Rotors on Teg (JDM LUDE)
have the rotors redrilled. Hybrid-perf has a writeup on this, Accord wagon calipers (essentially ITR) w/ prelude VTEC rotors redrilled to 4x100.
Old Apr 16, 2002 | 10:24 AM
bps2799's Avatar
Problem is, they are going on an Integra, not a Prelude.
Old Apr 16, 2002 | 10:49 AM
TypeSH's Avatar
There are integra guys who have done the NSX caliper swap. The legend ones should be pretty much the same swap.
90jdmda90
May 14, 2008 06:19 PM
ED9man
Jul 13, 2007 02:39 PM
jomama
Nov 14, 2006 06:06 PM
92TypeR
Feb 15, 2006 10:28 PM
