Squeaky windows
Old Sep 30, 2007 | 08:28 AM
  #26
SkyliteCustomz's Avatar
thanks for the input people
Old Oct 3, 2007 | 05:23 PM
  #27
UPDATE. i just fixed the squeaky problem, well tried to anyways. I use spray silicone to spray the tracks and what not. Worked a little bit. I found one of the little clip cushions on the door had fallen off into the door, so i put that back on. The window stopped squeaking, but after rolling the window up and down numerous time, the problem began to come back slowly. So i dont kno what the hell it could be now. BUMP FOR A SOLUTION
Old Oct 3, 2007 | 06:20 PM
  #28
__oversea's Avatar
Default Re: (SkyliteCustomz)
is it only making sound when window is almost all the way up? where the rubber trim and window glass is touching?
Old Oct 3, 2007 | 06:27 PM
  #29
jdm_bones's Avatar
Default Re: Squeaky windows (SkyliteCustomz)
Buy some white lithium grease and apply it to the window rails, you will have to remove your door panels for this job!
Old Oct 3, 2007 | 08:51 PM
  #30
CompanyFlow's Avatar
Default Re: Squeaky windows (jdm_bones)
Lithium grease has a tendency to get sticky, and almost gluey.
Old Oct 4, 2007 | 12:19 AM
  #31
also tried white lithium grease, still not helping. BUMP this **** is annoying the hell out of me
Old Oct 4, 2007 | 08:40 PM
  #32
davidv433's Avatar
try this, roll the window down, clean the rubber where the window slides and then lube it with silicone spray, is the rubber already dry and cracked ?
Old Oct 4, 2007 | 08:59 PM
  #33
Did you lube the sides?
Old Oct 5, 2007 | 06:22 AM
  #34
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What about conditioning the rubber with some rubber/vinyl dressing from like Meguiar's or something?
Old Oct 7, 2007 | 02:45 AM
  #35
the rubber isnt dry or cracked..still in good condition, but imma try it anyways. Sounds like a good plan, i'll let you know how it works out
Old Oct 7, 2007 | 10:02 AM
  #36
davidv433's Avatar
ive had that problem at work on some 07 hondas, it happens when u drive and leave the windows down. if u cant get in the tight spots, try q-tips or a rag on the end of a flat head screwdriver
Old Oct 10, 2007 | 12:25 AM
  #37
tried it, still faintly squeaking. I know most people wouldn't have a problem with it, but the fact that it's there annoys the hell out of me. BUMP! i know someone out there has to have a solution.
Old Oct 11, 2007 | 08:30 PM
  #38
davidv433's Avatar
can u pinpoint exactly where the squeak is coming from ? take off the door panel and see if it still does it, just leave the window switch plugged in. sometimes it could the track in the middle.
Old Mar 16, 2008 | 07:23 PM
  #39
UPDATE..after months of putting up with the fuking squeak i finally found out the problem. The previous owner installed the driver side mirror with some big *** screws that stuck out more than an OEM screw would, causing the window to squeak as it rubbed up against the screw. Replaced the screw problem solve.. LAGGING FTW! lol
ohemgiii
Oct 2, 2015 03:48 PM
deerman2701
Nov 27, 2007 05:59 AM
RAiMA
May 28, 2003 10:24 AM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
gsrhunny
Oct 2, 2002 11:23 AM
