Problem with start up only when cold
Old Jan 4, 2011 | 03:55 PM
lyzer227's Avatar
Default Problem with start up only when cold
I have a 94 Integra LS motor in my 94 Civic ex. The problem that i have with my car is everytime i try to start it (only when its cold) it dies on me. when it trys to turn on it boggs and dies if i happen to get it started I have to give it gas and the idle goes up and down and sometimes dies. AGAIN this only happens when its cold when the car is warmming up the car starts up fine and runs perfect no loss of power, smoke, or any problems when the car is warmed up. then i go to sleep or leave the car off for a long time the same thing happens. HELP IF YOU HAVE N IDEA WHAT IT COULD BE. and for those of you that are rude i dont need anyone saying "take it to a shop" or "dont mess with your car cuz u have no idea what you are doing" ONLY POST IF YOU HAVE SOMETHING GOOD TO SAY THAT WOULD HELP ME OUT THANKS.
Old Jan 4, 2011 | 05:28 PM
94 ls-r's Avatar
Default Re: Problem with start up only when cold
Clean the iac valve. Also check dizzy cap for moisture
Old Jan 4, 2011 | 05:50 PM
aquito's Avatar
That is exactly what's happening to my DA with b16 swap..just when it's super cold morning
Old Jan 4, 2011 | 07:19 PM
Bowl_of_Rice's Avatar
have you been noticing bad gas milage? check your ect sensor
Old Jan 4, 2011 | 07:20 PM
highwhey's Avatar
also happening to me. it started after i replaced a broken ditributor rotor. will not turn over on the first attempt...
Old Jan 4, 2011 | 08:54 PM
lyzer227's Avatar
I will clean the IAC tomorrow and i checked the dizzy and there is no moisture
I havent noticed bad gas mileage but the ECT is missed up i had to jump the connector cuz it wasnt turnning my fan on.
well when i checked the rotor and i noticed that the screw that holds it down wasnt there so i replaced it but it still lags it to turn on.
Old Jan 5, 2011 | 08:33 AM
that could be why the ect sensor is what tells the ecu if the motor is running cold or warm if its running cold then its gonna keep dumping fuel into the car then when its cold itll want to stall out get a new plug and new sensor and see what happens its only 27 dollars at the dealership and the plug just get it at a junkyard
Old Jan 5, 2011 | 08:46 AM
lyzer227's Avatar
i will chEck it out. thanks man
Old Jan 5, 2011 | 09:24 AM
highwhey's Avatar
same exact thing happened to me haha, the screw wasn't in place, and so the rotor broke. but yeah mines lags horribly...
end005
Sep 28, 2012 03:47 AM
crashtest2600
May 14, 2012 02:33 PM
99siRACER
Jan 17, 2012 03:47 PM
95goldSE
Sep 12, 2007 03:38 PM
GsTeg90
May 6, 2003 05:02 AM
