performance problems
Old Jul 20, 2005 | 06:47 PM
acura2gq's Avatar
Default performance problems
Ok here goes. I got a 65mm throttle body for my ls integra. Its a edlebroke with the calibrated tps but its for a type r. Everything bolts up. SO I put it on and my engine reves up and down. So I try adjusting the tps doesnt work. So I put my factory one my throttle body tps on does the same thing even after trying to adjust it. So I take it off thinking its the ecu not working with it. So I get a obd 1 computer and harness with the jun chip put it all back in and it still does the same thing!! But doesnt do it with my factory throttle body. But with the up graded ecu in now my car reves past 7grand but when my tac gets to 7 it goes straight to 0 but keeps reeving higher. So I dont know what the hell to do with this damn throttle body and I dont know whats up with my ecu. I dont think I really felt any dif with the ecu in neither. My mods I got on my car are catback header air intake and I got a str fuel rail i aint tried to put on with the new ecu but with the factory it gave me a code saying its getting to much gas so i took it off. Didnt have a adj. fuel pressure regulator thought just factory one on it. Well if anyone can give me some info it would be greatly appreciated
Old Jul 20, 2005 | 07:19 PM
93_teg_CT's Avatar
Default Re: performance problems (acura2gq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura2gq &raquo;</TD></TR><TR><TD CLASS="quote">SO I put it on and my engine reves up and down. d</TD></TR></TABLE>
check all the vacuum lines on?
Old Jul 20, 2005 | 07:22 PM
acura2gq's Avatar
Yeah its not vacuum. Cause I can put the 65 on and it does it and then I put the factory one back on and it stops
Type 56
May 23, 2017 06:59 AM
boostcrx89
Jan 6, 2008 05:46 PM
racereaper7
Aug 25, 2007 02:21 PM
Si99Civic
10
Apr 10, 2007 05:49 PM
c0nspire
Oct 23, 2004 08:00 PM
