oil pressure gauge install
im gonna use the feed from the stock oil pressure sensor. im NOT gonna T off the block in order to reuse the stock sensor. just connect the gauge line only. now for the wire that comes off the stock sensor, do i need to tie it to ground or just cut it and tape it up? the oil pressure light wont come on right?
Re: oil pressure gauge install (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 »</TD></TR><TR><TD CLASS="quote">if you have a vtec engine it needs to t'ed and hooked up otherwise ecu sends everything into safe mode.</TD></TR></TABLE>
are you thinking about the oil pressure switch thats in the head?
Re: oil pressure gauge install (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">are you thinking about the oil pressure switch thats in the head?</TD></TR></TABLE>
nope the sensor on the block to the left of where the oil filter goes.
okay i was do n a little research and i came upon a thread that said i need to use a 1/8" BSPT male fitting (screws into where the stock pressure sensor would be) with a 1/8" NPT female end (for the autometer gauge).
cant I screw in the autometer brass fitting directly to the block? well i went to autozone to get the BSPT to NPT fitting and they didnt have it so i went to home depot and couldnt find it either. so where can i get this fitting? also do i need this fitting or can the autometer peice just screw into the block?
i got this from another thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Please don't use an npt thread. It's not the right one, and I think most of the "don't T off the block" stuff was created by people putting the wrong threads in the block. http://www.tunertoys.com has a fitting with the correct threads, and it will give you two outlets to do whatever you wish with them, or plug them. </TD></TR></TABLE>
Re: oil pressure gauge install (ps2wiz)
so anyone ever used the stock fittings that come with the autometer gauges? if u have do u have n e leacks or did it work great?
Re: oil pressure gauge install (boosted k20)
why half *** it
http://www.fast-turbo.com/Turbolines.html
Firewall Oil Supply Distribution Line Kit
Im using the kit, its a great deal
comes with eveything
zero leaks
everything fits perfectly
zero leaks
the tuner toys fitting is still going to be too heavy
the added weight , plus the movement of the engine will cause the soft aluminum block to break
Stan's remote line kit is hell of a deal. I can't put one together for less than $30 with all the same parts using Aeroquip stuff.
I think I've experimented with trying to thread 1/8" NPT fittings in the block's 1/8" BSPT hole, and it doesn't work unless you force it...which just ends up shredding up the alumium.
Re: oil pressure gauge install (IN VTEC)
the BSPT fitting alone costs $10 from autometer
I wasn't able to price together a cheaper setup
and i'll be adding a sensor for an additional oil pressure light, and this kit has provision to add another sensor
RACEPAK
10-24-2005 04:23 PM
