oil pressure
Old Mar 9, 2004 | 04:18 PM
Audi RS4's Avatar
Lover
Default oil pressure
while auto Xing i had this gut feeling something was wrong and could not tell if vtec was crossing over, so i want to install a pressure gauge for a little while to monitor the oil pressure, just wondering if I use a T where the stock oil sending unit is and install both the external gauge and stock sensor
TIA
Modified by AK1200 at 6:26 PM 3/9/2004
Old Mar 9, 2004 | 05:11 PM
RedlinedVTEC's Avatar
Default Re: oil pressure (AK1200)
The stock oil pressure sensor is not connected to your ECU. It is a dummy switch that runs to the light on your cluster.
With that said when you install the gauge do not under any circumstance tee off the block!!! Run a SS line to the firewall and tee from there, the vibrations from the engine can shatter the brass tee causing very quick loss of oil and pressure = motor done. http://www.theoldone.com/articles/oilpressure/
Old Mar 9, 2004 | 05:20 PM
Audi RS4's Avatar
Lover
Default Re: oil pressure (RedlinedVTEC)
thank you for making me pull my head out of my *** for that brief minute.
thanks for the site
velisma
Jan 30, 2010 08:24 PM
EFsideways
Jan 1, 2008 01:52 PM
torqueless
Apr 19, 2007 03:29 AM
B18badboy
Apr 12, 2006 07:17 PM
hatchy
Aug 21, 2002 07:42 PM
