odometer
Old Jul 30, 2003 | 08:23 PM
E Lude U's Avatar
Default odometer
i had a little problem tonight driving home from work. the whole time i was driving the odometer never worked. it stayed at 0 the whole time. the rpm's worked fine but not the odometer. help me out to let me know whats wrong and what i need to do
Old Jul 30, 2003 | 08:33 PM
E Lude U's Avatar
Default Re: speedometer (E Lude U)
ok its true i did go have a couple drinks after work and yes its true i did put odometer when i meant speedometer
Old Jul 31, 2003 | 07:52 AM
prelittlelude's Avatar
so which is it, you speedo thats not working or you odometer, cehck you back up fuse , its the one that control the whole gauge cluster, and is the check engine light on?
Old Jul 31, 2003 | 08:19 AM
Sephro's Avatar
Default Re: speedometer (prelittlelude)
Also check the plug on your speed sensor. If that popped off it won't work at all.
Old Aug 1, 2003 | 10:22 AM
E Lude U's Avatar
Default Re: speedometer (Sephro)
no check engine light is on. just the speedometer isnt working. where is the speed sensor at? also i dont know if this will help or not but this same thing happened like a month ago for about 2 minutes then it shot up to the speed i was going. let me know what i need to do here
Old Aug 1, 2003 | 10:47 AM
Sephro's Avatar
The speed sensor is located in the rear of the transmission. It is next to the rear motor mount. It will have a plug on the top and 2 hoses coming out of it. You can see one in this thread https://honda-tech.com/zerothread?id=579741
Push on the plug and make sure it's connected securely
kindness
Aug 31, 2012 11:20 AM
civic_66
12
Sep 14, 2008 12:24 PM
krazieV
Aug 7, 2008 08:43 PM
turismo128
Sep 27, 2005 03:22 PM
speed.freak
Jun 8, 2005 01:40 PM
