obd1???
Old Sep 23, 2003 | 06:01 AM
matttegra's Avatar
Default obd1???
sup guys i'm planning on getting an obd1 ECU for my 99 gsr. Does it fit right in, or do I have to change things.
Modified by matttegra at 7:04 PM 9/23/2003
Old Sep 23, 2003 | 07:35 AM
IMPATIENT's Avatar
Default Re: obd1??? (matttegra)
what?........what are you getting for your car?.....
Old Sep 23, 2003 | 07:51 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matttegra &raquo;</TD></TR><TR><TD CLASS="quote">sup guys i'm planning on getting an obd1 for my 99 gsr. Do I have do reset something or something with my car or can I replace it right away and work.
thanks</TD></TR></TABLE>
please do no post when your under the infuence of drugs... LOL
well i think he wants to know if he can just get a OBD1 GSR complete harness and plug it up to his OBD2 GSR.
I know that he will need a OBD1 distributor and altenator correct?
1) can you even take out the COMPLETE harness (with fuel injector) while the car is intack to the engine bay?
Old Sep 23, 2003 | 08:04 AM
TimoneX's Avatar
New User
Default Re: obd1??? (Charlie Moua)
Nah I think he just means he wants to get an OBD I ECU and adaptor harness for it. You'll already be reseting it by swapping computers in that case. Just pull the ECU fuse prior to swapping and you'll be good to go.
Old Sep 23, 2003 | 09:31 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
please do no post when your under the infuence of drugs... LOL </TD></TR></TABLE>
BAHAHAHAHA!! That made me laugh out loud!
Old Sep 23, 2003 | 10:04 AM
matttegra's Avatar
ttt
Old Sep 23, 2003 | 12:34 PM
TimoneX's Avatar
New User
Default Re: (matttegra)
There's very little to do as I said. Simply insure that you get the correct adaptor harness and ECU(P28 most likely) pull the fuses and swap computers. It's a very simple transplant.
Old Sep 23, 2003 | 02:47 PM
skunkintegra's Avatar
Default Re: (TimoneX)
Matt--
search under archives for threads by "Kenji"
u'll find all the info u need!!
Old Sep 23, 2003 | 03:10 PM
Cramerox's Avatar
1) can you even take out the COMPLETE harness (with fuel injector) while the car is intack to the engine bay? </TD></TR></TABLE>
UHH no you do not need a obd1 dist nor a alternator. you just need a obd2-obd1 harnest. GO to the FI board and Ben@importparts are selling them for 100 bucks each.
Here for all you lazy asses
https://honda-tech.com/zerothread?id=617762
Old Sep 23, 2003 | 03:24 PM
andlude's Avatar
its so easy to swap over. all you need is the OBD2-OBD1 harness. i got the best and bought the Skunk2 Harness. it cost $235, but its well worth it. just make you get the ECU chipped when you get it. That is well worth it. Stock cams work good till about 8500 RPM thats about it. Plus the valve train cant really handle to much higher so be carefull. I definatly felt the power gain, its a really nice. Night and Day.
Old Sep 23, 2003 | 03:35 PM
IntEGNYC's Avatar
Default Re: obd1??? (andlude)
the wiring harness adapter should be all you would need. Good luck with your modding.
Old Sep 23, 2003 | 06:12 PM
Cramerox's Avatar
its only 100 bucks right now
Old Sep 24, 2003 | 05:55 AM
matttegra's Avatar
do you think that a p72 from a 94-95 GSR would also work.
Old Sep 24, 2003 | 08:27 AM
TimoneX's Avatar
New User
Yeah the an obdI P72 is fine. Most people go with the P28(myself included) for wider availability and lower cost, but either works.
Old Sep 24, 2003 | 04:16 PM
Cramerox's Avatar
it would work but your secondaries wont function properly with the p28
Nisif
Oct 20, 2012 06:11 PM
lilo_goki
11
Feb 15, 2008 12:07 PM
saleensolution
Oct 25, 2005 04:42 PM
GSRHATCH187
Oct 23, 2003 10:22 AM
slowhatch4now
Sep 19, 2003 06:28 AM
