cold start
Old Nov 16, 2005 | 03:21 PM
00-501itrspec's Avatar
Default cold start
no complaints , i just started my car to warm it up , and when i was running behind it back to my house , i realized how much i love this car , and thats pretty much it , just another person in love with their ITR
Old Nov 16, 2005 | 03:28 PM
tuan...'s Avatar
my car starts up kinda rough when its cold... i hope its normal
Old Nov 16, 2005 | 05:03 PM
tequilakid's Avatar
Default Re: (Racebred H)
I thought the idle speed in closed loop mode was based on the coolent temperature, not set at a specific rpm.
Old Nov 16, 2005 | 05:28 PM
tuan...'s Avatar
i know it suppose to idle high. I meant when the motor is cold, like in the morning, it STARTS up kinda rough. Not as crisp as it usually does.
Old Nov 16, 2005 | 05:32 PM
vtec.dc2's Avatar
Default Re: (RRa_kcaLb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RRa_kcaLb &raquo;</TD></TR><TR><TD CLASS="quote">i know it suppose to idle high. I meant when the motor is cold, like in the morning, it STARTS up kinda rough. Not as crisp as it usually does. </TD></TR></TABLE>
clearances change as it warms up so it sounds different.. unless by rough you mean dying idle or rpm jumping up/down?
Old Nov 16, 2005 | 05:37 PM
totsie7944's Avatar
Default Re: (vtec.dc2)
Mine is rough to in the cold, but once it gets some fuel in there its fine. USually have to give it some gas to start up
Old Nov 16, 2005 | 05:41 PM
vtec.dc2's Avatar
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">Mine is rough to in the cold, but once it gets some fuel in there its fine. USually have to give it some gas to start up</TD></TR></TABLE>
do you still have fuel evap switched plugged in? if running hondata on obd2 integra that will mess up your idle, one way is to unplug the switch, i tried that and it worked for some time, but it still seemed like fumes were getting through, so i disconnected the hose to IM and plugged it with a screw so nothing blows up.. it will eventually settle and exit underneath
Old Nov 16, 2005 | 05:55 PM
totsie7944's Avatar
The car idles fine seriously after like 10 seconds... when tuning today Jeff was sayign how the cold start fuels were messy he cleaned it up alot on the tune, but the cams I have and what not don't make for a smooth start up in cold ne way... the caR lobes alot at first
Old Nov 17, 2005 | 04:25 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">The car idles fine seriously after like 10 seconds... when tuning today Jeff was sayign how the cold start fuels were messy he cleaned it up alot on the tune, but the cams I have and what not don't make for a smooth start up in cold ne way... the caR lobes alot at first</TD></TR></TABLE>
my question is.... do you have the evap switch still plugged in? )its mounted on firewall and has larger vacuum hose connect to IM)
Sic_DA_Nine
Jun 16, 2006 11:14 PM
Takashi1978
Jan 31, 2006 03:55 AM
rough_draft
Jan 12, 2005 11:12 AM
94dxt
Aug 14, 2003 09:03 PM
