Nitrous
Old Oct 24, 2006 | 08:50 AM
Speed94's Avatar
Default Nitrous
Can I run a 50 shot safely with an otherwise stock LS/VTEC with boost? its an SC34 and looking to put down 300 or so to the ground. Thanks.
Old Oct 24, 2006 | 08:55 AM
IHTFP's Avatar
Default Re: Nitrous (Speed94)
couldnt you make 300whp w/o the nitrous???
i dont know the answer to your question, but if you do, get it retuned for sure
Old Oct 24, 2006 | 11:05 AM
jinteg730's Avatar
Default Re: Nitrous (IHTFP)
boosted lsvtec? gotta be close to 300whp... and i would say definately within 35 so get a 35 shot i know 15 less horse seems like nothin but if ur happy with 300 stay safer and dont blow an lsvtec.. my experieces witht hem have been so so but keep it safe its a good strong motor
Old Oct 24, 2006 | 11:22 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Nitrous (jinteg730)
i would think you can make 300 without the NAWWzz with your setup, how much boost are you running
Old Oct 24, 2006 | 12:23 PM
Speed94's Avatar
Default Re: Nitrous (It's*BOLO!!)
no idea how much boost yet...whatever is safe on the block...all I have is a Golden eagle block guard. Probably gonna run methanol injection too
Old Oct 26, 2006 | 09:32 AM
Speed94's Avatar
bump for some more opinions
Old Oct 26, 2006 | 10:54 AM
Tizight's Avatar
lsv boosted should get you 300 already with a good tune. But yeah 35 woudl be fine I think I hear of people with 100 shots and thier cars are tip tio shape.
Old Oct 26, 2006 | 11:10 AM
scottishdave's Avatar
Default Re: (Tizight)
dont even touch the n20, you can get your 300hp fix with boost. take the cash you were going to spend on n20, save a little more and buy some pistons/rods/hea studs and you will be able to boost the car way past 300hp
Old Oct 26, 2006 | 11:33 AM
cm zak's Avatar
300hp with nos and boost? Dude you could do it with just boost..
Old Oct 26, 2006 | 12:28 PM
B18B1_4DR's Avatar
Default Re: (cm zak)
Don't touch the spray. You can achieve 300whp with a boosted LS/VTEC w/ the help of a good tuner. Although I really don't know what you've done internal wise.
Old Oct 27, 2006 | 04:46 AM
Speed94's Avatar
Default Re: (B18B1_4DR)
I already have the Nitrous...i was going to originally use it for an intercooler sprayer, but I figured since I have it, I might as well put it in. I have headstuds already and rod bolts are on the way. Pistons and Rods i am going to do on the second motor build.
EGlsVtak
Oct 24, 2007 11:09 AM
typesguy
Feb 26, 2004 01:58 PM
TypeR1558
Sep 25, 2002 02:51 PM
KoRE
Aug 18, 2002 02:18 PM
turbofasteg
Apr 14, 2002 05:43 PM
