How big of a shot would be safe?
Old Aug 15, 2002 | 09:51 PM
KoRE's Avatar
Default How big of a shot would be safe?
the setup:
d16z6 Greddy Turbo 13-15 psi(haven't decided)
Dsm 450cc injectors
s-afc hack
Ross 9.4:1 comp pistons
Eagle rods
Walbro intank fuel pump
I want to run nitrous with it also but i want to do a 75 shot but i dunno if it would be ok with stock sleeves what do you think? or should i just do a 50 shot?
my goals are(on drag radials): mid to high 13's without the nitrous but 12's with the nitrous.
any opinions good or bad will be useful.
Old Aug 15, 2002 | 11:06 PM
RicerRacing69's Avatar
Default Re: How big of a shot would be safe? (KoRE)
@ 13-15psi you should be able to hit high 12's w/o N2O if your a good driver, n20 might even put you in the high 11's
Old Aug 16, 2002 | 12:57 AM
dubster99's Avatar
Default Re: How big of a shot would be safe? (RicerRacing69)
On a stock sleeve, you're pushing it running 13-15lbs of boost plus nitrous. Your best bet is to use a dry kit to cool the intake charge, maybe run just a 25 shot. A 25 shot on a turbo/sc motor has seen results of 50+ whp just for cooling the charge. If you want to run a decent shot plus that much boost, you'll need to get that block resleeved.
Hey RicerRacing69....what was your setup on the juiced LS for that 14.18? That's a good time for a 55 shot
[Modified by dubster99, 9:58 AM 8/16/2002]
Old Aug 16, 2002 | 09:53 AM
KoRE's Avatar
Default Re: How big of a shot would be safe? (dubster99)
what kits can shoot that low? zex only goes down to 55 and nx and nos i thoguht the lowest were 50...
should i just look into a sneaky pete kit? and just buy a bigger bottle?
i need more info and more opinions....
thanks for the help
Old Aug 16, 2002 | 09:57 AM
CovertFI's Avatar
i bet if you call zex they can get you the right nozzel for you set up. not many people spray 25hp shot
Old Aug 16, 2002 | 10:03 AM
speshuled619's Avatar
yeah your gonna want to sleeve the block with that much abuse. i would also go with what everyone is saying and do the 25 shot to cool it down. it does work.
KoRE's Avatar
Default Re: How big of a shot would be safe? (CovertFI)
well covert do you think i would be fine with a 50 shot? i might even just get a direct port kit if this guy is willing to trade.....
i'll call up the companies to see what's the lowest shot...
or do you think i should just buy a sneaky pete kit?
Old Aug 16, 2002 | 10:08 AM
CovertFI's Avatar
it is a hard call. personally i would just buy the kit if it is a good deal. but how fast is your car already. most of the guys on this site are not even on the bottle. even with my t3/t4 i have a quick *** spool. i would wait to see how your car does as is.
Old Aug 16, 2002 | 10:11 AM
KoRE's Avatar
hmmm ok after the rebuild and everything and it's all broken in i'll take it to the track and see how close i am to my goal.....but i still want to run the nitrous....
i don't want thenitrous to spool it up faster cause my greddy turbo spools up like nothing... i just want it for the extra power.
thanx for the help btw
Old Aug 16, 2002 | 11:25 AM
I have Skunk 2 modified for LS Intake man, 5 angle port and polish, custom bored TB, Pulleys, cam gears, I/H/E, and a set of radials.
If you want a N2O system I have mine up for sale with bottle heater, blanket, and autometer bottle pressure gauge f/s with some custom made shot sizes i have bored. If you want a 25 shot, i can make you one, PM me if your interested.
Old Aug 16, 2002 | 04:14 PM
dubster99's Avatar
Yes you can get jets for a smaller than 55 shot
Old Aug 16, 2002 | 07:22 PM
KoRE's Avatar
well i still don't understand why a wet kit would cool less then a a dry kit?
um also 50 is too much then?
Old Aug 16, 2002 | 08:32 PM
wickedxboi's Avatar
a wet kit is when you mix gas and nitrous into the intake charge, such as nitrous express or nos brand. a dry kit is just spraying nitrous into the intake charge, such as the zex kit. ive heard people get better results with a wet kit.
Old Aug 16, 2002 | 08:48 PM
Brian_92GSR's Avatar
New User
Getting the right size jets won't be a problem at all. You can order any size they make for NOS from jegs. And the smaller sizes are common because of direct port kits (since they would be using 4 nozzels each jet is smaller that just using one.
Old Aug 16, 2002 | 09:11 PM
KoRE's Avatar
Default Re: How big of a shot would be safe? (wickedxboi)
I knew what the diference was. i just don't get why people were telling me a dry would cool better.
so a wet kit would work better?
cause i don't want to lean out that's what i'm afraid of.
Old Aug 17, 2002 | 02:06 AM
dubster99's Avatar
With a turbo setup, go dry.
Old Aug 17, 2002 | 06:32 AM
KoRE's Avatar
ok.... i'm gonna trust you lol
thanx for all the help...
now i need to find a dry kit
Old Aug 17, 2002 | 07:35 PM
dubster99's Avatar
For a small sized shot say 25-50 to cool the intake charge, dry is the setup to go with. If you are doing it for power, and want to go higher than that with a built motor, go direct port.
Old Aug 17, 2002 | 09:01 PM
KoRE's Avatar
well i really want it for power but while doin that cool the intake charge...but i think i'm just gonna stick with a 50 shot....
anyone got a NOS kit? im me.....
Old Aug 18, 2002 | 01:15 AM
dubster99's Avatar
If you want it for cooling, use dry kit 25-50....I have seen 50 whp gains from a 25 shot just from cooling the intake charge.
Old Aug 18, 2002 | 07:05 AM
Ltech's Avatar
50 shot dry will do for you. Look for them on Ebay.
Old Aug 18, 2002 | 07:46 AM
KoRE's Avatar
Default Re: How big of a shot would be safe? (Ltech)
yeah i'm trying to find one local if possible thoguh....but if it comes down to it ebay is the way to go
THanks for all the help.
Old Aug 18, 2002 | 10:19 AM
redteg1's Avatar
a shot of your mouth around my **** should do just fine
Old Aug 18, 2002 | 11:43 AM
KoRE's Avatar
Default Re: How big of a shot would be safe? (redteg1)
dude thats gross.....
but here...enlarge this picture then print it out.... then you can have all the fun you want.
Old Aug 18, 2002 | 02:18 PM
KoRE's Avatar
hey my friend might be selling his direct port kit so i was wondering if the cooling efficiency is any less on that then on a dry kit....
thanx
Lonewolf1983
Oct 3, 2014 02:55 AM
luis253
Jul 11, 2014 05:37 AM
1cln_eg9
May 17, 2010 03:20 PM
1 Cam Wonder
Nov 26, 2004 11:30 AM
WhiteLS
Sep 21, 2003 11:34 AM
