Need help spring install
Old Aug 19, 2004 | 11:38 AM
njandrewg's Avatar
Default Need help spring install
I am installing my stock springs back and have a problem
the fork is now so low and no amount of pushing down or up moves it...its stuck
anyone have any ideas?
Old Aug 19, 2004 | 11:41 AM
timmy8151's Avatar
Default Re: Need help spring install (njandrewg)
Try using a jack to push up the fork.
Old Aug 19, 2004 | 11:55 AM
njandrewg's Avatar
Default Re: Need help spring install (timmy8151)
doesn't help jacks up the whole assembly
Old Aug 19, 2004 | 12:38 PM
njandrewg's Avatar
got it fixed
doesnt' this look a lil bit too low tho?
I do have theo ther side jacked up so that it'd be easier to lower the rotor
Old Aug 19, 2004 | 12:58 PM
jweezy225's Avatar
be happy you got the bolt out of the shock, mine just snapped
Old Aug 19, 2004 | 01:04 PM
Marauder's Avatar
Default Re: Need help spring install (jweezy225)
Have someone push down on the rotor.
Old Aug 19, 2004 | 01:16 PM
simon98h22's Avatar
Default Re: Need help spring install (Marauder)
I would have said use a jack but if it's stuck, try jamming something between the top of the wheel well and the rotor/hub and then carefuly jack it up from the bottom.
Old Aug 19, 2004 | 01:25 PM
njandrewg's Avatar
Default Re: Need help spring install (simon98h22)
well I already got it fixed...just took some jumping up and down on it with all my body wieght and a long jack pole to push it along heh
pain in the ***...reason I'm doing this is I stripped the head when installing my rear springs so I want to throw it back to stock for now until spring time hwen I get some shocks then pay the 50 bucks per side to get that rear one fixed by the shop...reason I stripped is stupid me iddn't notice I had a 12pt socket instaed of a 6 pt
Old Aug 19, 2004 | 01:34 PM
dFreezy's Avatar
were you running stock shocks and aftermarket springs before?
Old Aug 19, 2004 | 01:52 PM
njandrewg's Avatar
Default Re: Need help spring install (bl@sterVT)
yes but for a grand total of 20 miles. The car was lowered on just the fronts and I needed to make an emergency errand.
Old Aug 19, 2004 | 01:54 PM
njandrewg's Avatar
and the good news its back to its normal height at taht one side
Old Aug 19, 2004 | 02:17 PM
TURBODC4TEG's Avatar
cool
crx(gator)
Aug 1, 2008 08:11 PM
SwiftTypeR
Jan 29, 2006 10:25 PM
.brad
Aug 13, 2003 03:09 AM
MachAF
Mar 23, 2003 08:20 AM
