Spring Install Help Needed...
Old Aug 12, 2003 | 07:44 PM
.brad's Avatar
25 Year Member
Default Spring Install Help Needed...
When I try to loosen this bolt the shaft spins. How can I keep it from doing this?
Old Aug 12, 2003 | 08:03 PM
Mr. Choi's Avatar
New User
Default Re: Spring Install Help Needed... (.brad)
see that hole in the middle of the threads? you place a 5mm allen key/wrench, hold, and loosen.
Old Aug 12, 2003 | 10:25 PM
Turbogixxer's Avatar
Default Re: Spring Install Help Needed... (Mr. Choi)
Yep, Use an allen key (5mm) to hold it and a combination wrench (14mm) you loose it. Hope for the best, I have had 2 of the struts (the allen key part) strip out on me.
Old Aug 13, 2003 | 03:09 AM
J2turbo21's Avatar
Make sure you have a spring compressor cause that thing will shoot out on you if your not carefull.
oakpwr
Jan 27, 2007 01:08 PM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
MachAF
Mar 23, 2003 08:20 AM
MachAF
Mar 23, 2003 03:42 AM
00fbp
10
Dec 13, 2002 12:02 AM
