spring install problem
Old Jan 28, 2006 | 09:25 PM
SwiftTypeR's Avatar
New User
Default spring install problem
The front right bolt goes in almost twice as deep as the front left. Does that mean my shock is blown or we installed it wrong? When I push down on the vehicle, the front right side makes squeeking noises from the spring. The ride height is the same on both sides and the shock did not look like it was leaking fluid when we pulled it out. Help anyone?
Old Jan 28, 2006 | 11:33 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: spring install problem (SwiftTypeR)
Are both of the springs seated properly on the seat?
Sometimes it moves when you put the cap back on so you need to twist it back into place.
Old Jan 28, 2006 | 11:59 PM
_BEN_'s Avatar
You could have installed the "special washer" (aka bumpstop splate) upside down.
Item 14
It is tapered on the inside and if you set it on the shock upside down it will sit about 1/4" higher.
Old Jan 29, 2006 | 12:39 PM
SwiftTypeR's Avatar
New User
i figured it out, my shock is blown =[
Old Jan 29, 2006 | 12:45 PM
uNF$@#!'s Avatar
Default Re: (SwiftTypeR)
it happens.
Old Jan 29, 2006 | 07:08 PM
SwiftTypeR's Avatar
New User
looks like my shock wasnt blown, the washer was upside down. 3 out of 4 isnt bad...my friend did the initial install O_O i hope it doesnt prematurely wear out that shock now.
Old Jan 29, 2006 | 09:35 PM
Evs-One's Avatar
Solbros Owns Me
doesn't matter if your shock is blown or not, that will NOT effect the distance between the taper in the shock and the top of the threads. Only thing that will change that is lack of/extra washer, worn bushings, etc
Old Jan 29, 2006 | 10:25 PM
B7AudiA4's Avatar
glad you figured it out...
about your squeeking sound... Mine did it for a bit and the sound was gone
jrivehard
Suspension & Brakes
22
Dec 16, 2008 09:26 PM
oakpwr
Jan 27, 2007 01:08 PM
Beach Accord
Oct 18, 2004 03:09 PM
Daniel_san
Aug 31, 2004 12:49 PM
chris215chris
Aug 10, 2003 06:50 AM
