spring install help
Old Mar 22, 2003 | 10:38 PM
MachAF's Avatar
Default spring install help
I got the front spring installed fine. Here is my problem.
The left rear strut assembly where you have to use the allen wrench and a 14mm wrench to get that top bolt off ( so you can remove the spring), are both stripped. They were rusted over bigtime I think, WD40 wouldn't unrust them.
Anyone got an ideas for me? You can't really use those speical sockets for getting stripped nuts off because the bolt will just turn if an allen wrench is not used.
Old Mar 22, 2003 | 10:39 PM
xteg95's Avatar
Default Re: spring install help (machaf)
might have to drill it out and get new bolts :/
Old Mar 22, 2003 | 10:43 PM
Deluzional's Avatar
Default Re: spring install help (xintegra01)
I hack sawed it off when I was installing my adjustable KYB...drilling will also work
Old Mar 22, 2003 | 10:46 PM
tilt's Avatar
that happened to me. I think i used a small vice grip under the nut and pryed something between the vice and nut and made enough friction to keep it from turning.
also, maybe try one of those nut/bolt cracker tools.
Old Mar 22, 2003 | 10:58 PM
GSRaCeRbOI's Avatar
damn that sucks.. in over 15 spring/shock installs that has never happened to me.. but if I were in the situation after having the spring compressed, I'd probably get a large/strong Vise grip and set the jaws really small/tight so it gets a really tight grip on the shock rod/spindle... and hopefully it'll hold the shock rod/spindle stationary so that you can break loose the top shock mount nut...
I've never encountered this.. so no 1st hand experience... maybe you can get a bench vise and grip the top of the shock rod REALLY tight.. while having someone else support/hold the shock while you try to undo/break loose the nut...
or you could bust out the sawz all haha
just make sure the spring is compressed fully w/ a spring compresor so when things finally gets loose.. it doesn't shoot or injure anyone....
Old Mar 23, 2003 | 06:52 AM
MachAF's Avatar
So its possible just to buy the new bolt that goes up through the stock?
I have the car all back together. So its kinda ghetto looking, front lowered rear jacks up.hahah..oh well. Its my sisters car, spring install on my car went fine.
Looks like I'll try agian today. Anyone know the name of the nut? is its 14mm Flange nut with what pitch?
[Modified by machaf, 8:54 AM 3/23/2003]
Old Mar 23, 2003 | 08:20 AM
GSRaCeRbOI's Avatar
yeah you can buy pretty much any part from the dealer...
lolz its cheap too...41 cents
85403 021 2 NUT (10MM) 0.50 0.41
http://www.acuraautomotiveparts.org/...SHOCK+ABSORBER
oakpwr
Jan 27, 2007 01:08 PM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
.brad
Aug 13, 2003 03:09 AM
acatak
Apr 21, 2003 06:51 PM
MachAF
Mar 23, 2003 03:42 AM
