Need Help Please!!!!!!!!
Old 05-18-2008, 02:28 PM
memphisfuk's Avatar
Default Need Help Please!!!!!!!!
Ok so here is the problem. I have a 1990 acura integra with only a cold air intake and i cannot get it to run right anymore. When i bought the car it was running fine and then one day it started running like it had no compression once reaching operating temp. I thought maybe it was the head gasket so I pulled the head and the gasket was fine but I changed it and put everything back together just as before and the problem started again. I thought maybe it was the fuel injector resistor box? but I changed that and problem still is there.
If anyone else has had this problem or knows what else to try please help.
Any help will be very much appreciated.
Old 05-18-2008, 03:05 PM
spidy3's Avatar
Default Re: Need Help Please!!!!!!!! (memphisfuk)
compression test?
make sure there is spark from all wires
check fuel, maybe change filter
Old 05-19-2008, 06:48 PM
memphisfuk's Avatar
Default Re: Need Help Please!!!!!!!! (spidy3)
Yeah I did a compression check and everything is fine. I didn't even think about fuel filter. hm? and yes I have spark.....
thanks
Collinh91
02-04-2016 07:29 AM
thatoneguy374
06-08-2011 12:47 PM
DJone850
02-26-2004 11:34 PM
Butler230
07-16-2003 07:50 AM
Quick Reply: Need Help Please!!!!!!!!
