Need Help Please!!!!!!!!
Ok so here is the problem. I have a 1990 acura integra with only a cold air intake and i cannot get it to run right anymore. When i bought the car it was running fine and then one day it started running like it had no compression once reaching operating temp. I thought maybe it was the head gasket so I pulled the head and the gasket was fine but I changed it and put everything back together just as before and the problem started again. I thought maybe it was the fuel injector resistor box? but I changed that and problem still is there.
If anyone else has had this problem or knows what else to try please help. Any help will be very much appreciated. |
Re: Need Help Please!!!!!!!! (memphisfuk)
compression test?
make sure there is spark from all wires check fuel, maybe change filter |
Re: Need Help Please!!!!!!!! (spidy3)
Yeah I did a compression check and everything is fine. I didn't even think about fuel filter. hm? and yes I have spark.....
thanks |
