Missing Link on an LS Turbo
Old Dec 12, 2005 | 01:31 AM
yodas-gsr's Avatar
Default Missing Link on an LS Turbo
hey guys,
i have a recently acquired ls turbo, it doesnt have a missing link on the map sensor, but its got some tubing for vacumn near it, that im assuming is doing the same job, because the check engine light hasnt gone off. if that ol style stuff is working, is it worth it to buy a missing link and put it on...are there other benefits?
thanks,
yoda
Old Dec 12, 2005 | 07:30 AM
SSBPGSR's Avatar
Default Re: Missing Link on an LS Turbo (yodas-gsr)
that little nipple by it is pointless. have you been boosting the car?? what ECU is in the car? the stock virgin honda ECU's will throw a CEL when it sees boost. not at idle or under vaccuum. if its a chiped ECU then it wont throw a CEL reguardless, whcih is the reason for the socketing/chipping. basically if its a stock ECU you need a missing link, or some check valves ( but i recomend the missing link )
Old Dec 12, 2005 | 06:48 PM
yodas-gsr's Avatar
Default Re: Missing Link on an LS Turbo (SSBPGSR)
thanks for the info..
the stock ecu chip was flashed and its running about 10 pounds on a built bottom end. its a t3. no CEL codes
Old Dec 12, 2005 | 08:20 PM
Muckman's Avatar
Moderator in Chief
Dont touch anything. Your ECU is reflashed and it needs to see boost to properly function.
standbackimapro
Jun 8, 2008 11:10 PM
NJ VTECpowered
Jan 17, 2007 10:06 PM
97grnrs2
May 31, 2006 08:31 AM
yodas-gsr
Dec 12, 2005 04:13 AM
CJJones87
Sep 25, 2005 10:28 AM
