does obdo need a missing link ,.
Old May 29, 2006 | 05:23 AM
97grnrs2's Avatar
Default does obdo need a missing link ,.
do i need a missing link with obd0 ls ? it seems fine without it and i get no codes but i see some ppl are using one..
Old May 29, 2006 | 05:38 AM
crxnj's Avatar
Default Re: does obdo need a missing link ,. (97grnrs2)
if the ecu is not chipped to see boost then you need the missing link/check valves setup..and its not just because of obd0..
Old May 29, 2006 | 03:45 PM
97grnrs's Avatar
well wat does it actually do on an obd 0 car? i know on my other car it would cause the car to sputter between boost and vac transition without it but that was obd2 eclipse .. on my hatch it seems to not affect it at all not having one. no sputter or codes..
Old May 29, 2006 | 05:36 PM
xenocron's Avatar
Default Re: does obdo need a missing link ,. (97grnrs)
Give us the details on your fuel management setup...
ECU, Injectors...etc?
Old May 29, 2006 | 05:48 PM
97grnrs's Avatar
Default Re: does obdo need a missing link ,. (xenocron)
only fmu and stock LS injectors. runnin about 9 psi .. runs great but i was just wondering about the ML .
Old May 29, 2006 | 07:15 PM
xenocron's Avatar
If you are running stock ECU and injectors with an FMU and your ECU isnt flipping out in boost with no Missing Link installed...something is wrong or something is modified that you dont know about inside that ECU.
Old May 29, 2006 | 07:35 PM
b18sihatch's Avatar
^ was thinking the same thing. it should throw a CEL when it see's boost, if it doesnt sumthing is wrong
Old May 30, 2006 | 11:27 AM
97grnrs's Avatar
Default Re: does obdo need a missing link ,. (b18sihatch)
nope no cel.. stock 91 integra ecu.. car dont bog or do anything when it crosses into boost.. i was suprised to.
Old May 31, 2006 | 04:07 AM
xenocron's Avatar
I bet its chipped already...probably set for stock injectors and boost.
Old May 31, 2006 | 05:57 AM
redzcstandardhatch's Avatar
something different
yeah, thats probably the only explanation.
Old May 31, 2006 | 07:34 AM
b18sihatch's Avatar
welp if it doesnt do anything i would just go with it.
Old May 31, 2006 | 08:31 AM
97grnrs's Avatar
its only a stock ecu.. only thing it will do once in a while is idle kinda low after boost.. thats it..
standbackimapro
Jun 8, 2008 11:10 PM
NJ VTECpowered
Jan 17, 2007 10:06 PM
yodas-gsr
Dec 12, 2005 08:20 PM
CJJones87
Sep 25, 2005 10:28 AM
revhigh96
Aug 13, 2003 07:11 PM
