LS BOOSTING QUESTION
Old Oct 21, 2004 | 05:56 PM
Ls InTeGrA RaCeR's Avatar
Default LS BOOSTING QUESTION
Ok here's the situation. I'm buying a full Greddy kit along with a blow off valve and intercooler for my Ls (yes I know Greddy is a starter kit but hey...I'm a starter) and I plan on running it with my stock Internals until I get up the money to do a rebuild. So knowing what I'm working with what's a safe level of boost to run without running a rod threw my block? Also, could you recommend some good brands for rods and low compression pistons. Yes I know I'm going to need an uberdata (spelling?) or Hondata. Thanks.
Old Oct 21, 2004 | 06:30 PM
Finger Lickin' good's Avatar
Default Re: LS BOOSTING QUESTION (Ls InTeGrA RaCeR)
If I were to boost my 96 LS 118k miles, Id stay .5bar. So little psi, very valuable daily driver.
Old Oct 21, 2004 | 07:56 PM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
SEARCH!!!!!!
Old Oct 21, 2004 | 11:22 PM
sir boostalot's Avatar
I was in the exact situation when I bought my greddy turbo. u can boost higher than the preset 7psi but don't mess up your air/fuel ratio. don't put stress on your motor until doing a compression check.
There's people here pushin 9-10psi here on stock LS internals but there still not gettin full potential of boost without tuning. I didn't go over 8 pounds on stock.
Eagle and Crower are good companies for pistons.
Old Oct 21, 2004 | 11:52 PM
ojoemamao4o's Avatar
good kit, chill with the emanage and the 310 injectors...youll be just dandy...just learn how to drive a turbod car, boost through the first few gears, then just relax for about 10-15 mins, let everything cool down
just remember, your all stock still so keep the hype down or your melt 2 pistons like i did
Old Oct 22, 2004 | 02:27 AM
Default Re: (ojoemamao4o)
yeah its not the pistons I'm so much worried about. its the rods. so I'm going to be fine running 7 pounds with the Greddy Blue Box and 310 Injectors?
Old Oct 23, 2004 | 09:09 PM
Default Re: (Ls InTeGrA RaCeR)
yup
Old Oct 23, 2004 | 09:12 PM
gramentz's Avatar
Default Re: (ssboost)
I'm runnin mine at 10 pounds....I would definitely get it tuned pronto.
Old Oct 24, 2004 | 08:47 AM
BLacK FirE's Avatar
The new kits don't come with bluebox, they come with emanage and is much better than the bluebox.
Old Oct 24, 2004 | 08:55 AM
StolenTeg's Avatar
Default Re: (BLacK FirE)
Why are you scared with the Rod, I garuntee you they wont be the first one to go. It will mostly be your Ring/ringland if your tune properly, that the weakest part of our motor...
Old Oct 24, 2004 | 11:35 AM
blackeg's Avatar
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Why are you scared with the Rod, I garuntee you they wont be the first one to go. It will mostly be your Ring/ringland if your tune properly, that the weakest part of our motor...</TD></TR></TABLE>
you speak the truth
Old Oct 24, 2004 | 01:02 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">yeah its not the pistons I'm so much worried about. its the rods. so I'm going to be fine running 7 pounds with the Greddy Blue Box and 310 Injectors? </TD></TR></TABLE>
r u serious? the stock pistons suck.. the ringlands bite the dust under detonation very easily.. the stock rods are capable of holding power well up to 350WHP..the only time u need to worry about the stock rods is in a hydrolock situation (you need to worry about everything when this happens), or if your gonna rev well past the stock red line.
Old Oct 24, 2004 | 06:29 PM
cnydc2's Avatar
Default Re: (J337_UNIT)
Your factory block should easily hold 10 psi. Just have it tuned and it will be fine.
I am running JE 9:1 compression pistons, and Crower Pro-Billet Rods, this has been a great setup.
Old Oct 24, 2004 | 06:32 PM
TeaAddict's Avatar
Default Re: (cnydc2)
i think greddy suggest 7-8 psi
Old Oct 24, 2004 | 07:47 PM
POWERINTEGRA's Avatar
Default Re: (TeaAddict)
8 PSI max if you want this to last you
if you want more then do it right the 1st time if not you will waste your money and regret it later.
Do as greddy says 7 they know why they tell you this there is a reason for it
Old Oct 24, 2004 | 08:20 PM
mpintegra96's Avatar
i put my turbo on my car back in may with 105k on her, (didnt get on it at all for 2months!)didnt get it tuned till july because i was waiting on a 2mm cometic headgasket, now its almost november ive got 113k she is my daily driver about 55 miles everyday i drive it 90%expressway, its way too much fun but i dont beat on my car i baby it i get on it from time to time but baby it, just a little list of whats on my car 96 gsr stock block execpt arp headbolts,2mm cometic headgasket, drag 3 manifold&downpipe 2.5"carsound cat and 2.5" exaust
ballbearing t3/t4 custom intercooler piping,rc310's,vortechfmu,walbro 255lph and apexi vafc and avcr oh and i know its not a greddy kit but its just alittle help good luck greddy was my first choice but i should have saved for full-race
jamelin
Apr 9, 2009 02:22 PM
IntegraGSR-Turbo
Jun 4, 2006 08:05 PM
a2dadamm
Dec 30, 2005 02:30 PM
2FASTDC2
Jan 7, 2003 02:49 PM
mskibbz-T
Jun 18, 2002 09:50 AM
