boost on ls
Old Dec 30, 2005 | 11:51 AM
a2dadamm's Avatar
Default boost on ls
just curious to see if i turbo my ls with stock internals how much boost would be safe to run...
Old Dec 30, 2005 | 11:55 AM
tegbooster's Avatar
Default Re: boost on ls (a2dadamm)
technically 8-10lbs is safe on an LS engine... i would suggest you still reinforce your block and lower your compression, have it tuned properly (AEM EMS, Crome Pro, Uberdata, etc) and make sure your tuner knows what he's doing.....
also... search... check the F - I forum...i know this has been beat to death
Old Dec 30, 2005 | 11:58 AM
b20integrapower's Avatar
Default Re: boost on ls (tegbooster)
well the amount of boost you run also depends on the size of the turbo...8-10 lbs boost is different between turbos..but 8-10 is usually the # that gets thrown around...
Old Dec 30, 2005 | 12:11 PM
WhoDoYouThink's Avatar
Default Re: boost on ls (b20integrapower)
I have seen ALOT of guys with stock LS bottom ends pushing the 350whp mark. LS= good for boost
Old Dec 30, 2005 | 12:45 PM
BrooX's Avatar
Search Results
Your search for LS Turbo returned 47 results.
Very common subject my friend.
Old Dec 30, 2005 | 12:51 PM
sir boostalot's Avatar
Default Re: boost on ls (DA9GUY-637)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9GUY-637 &raquo;</TD></TR><TR><TD CLASS="quote">Search Results
Very common subject my friend. </TD></TR></TABLE>
That's certainly one way of putting it.
Old Dec 30, 2005 | 12:54 PM
BrooX's Avatar
Default Re: boost on ls (sir boostalot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir boostalot &raquo;</TD></TR><TR><TD CLASS="quote">
That's certainly one way of putting it.</TD></TR></TABLE>
Its certainly the easiest way of researching it rather than starting a thread over it which has been covered countless times. Just my .02
Old Dec 30, 2005 | 12:59 PM
elrandeeto's Avatar
as stated above its not really how many pounds of boost its how much hp . 350 hp is pushing it on stock ls , but with a healthy motor and good tune 300 or less safely
Old Dec 30, 2005 | 02:16 PM
lVlemphizStylez's Avatar
Default Re: boost on ls (elrandeeto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elrandeeto &raquo;</TD></TR><TR><TD CLASS="quote">as stated above its not really how many pounds of boost its how much hp . 350 hp is pushing it on stock ls , but with a healthy motor and good tune 300 or less safely</TD></TR></TABLE>
informed builder ...i thought almost everyone in this forum was on the lower level thinking of psi is universal
Old Dec 30, 2005 | 02:30 PM
Team Underground Teg's Avatar
Default Re: boost on ls (lVlemphizStylez)
Yeah an LS can take a fair amount of boost but it also depends how long you want the engine to last too....
Honda-ls-hatch
Oct 4, 2010 08:04 AM
fabe85
Dec 19, 2004 10:53 PM
SJcivic
Aug 19, 2004 10:10 AM
ninja8oi
May 13, 2003 06:59 AM
NightHawkC5
Jan 10, 2003 04:03 AM
