Idle issue plz help!!!
Old 04-18-2009, 08:18 PM
jrthestar's Avatar
Default Idle issue plz help!!!
Okay guys so i did a auto to manual conversion everything came out great except my car has a retarted idle issue. Sometimes it stays normal then out of no were it starts surging... What can it be!!!!!!!
Old 04-18-2009, 08:53 PM
New User
Granada_BP_DC4's Avatar
Icon2 Re: Idle issue plz help!!!
Me too !!! Before the conversion idle was always in normal range !
What could do that ???
Old 04-18-2009, 10:18 PM
ARdb8's Avatar
Default Re: Idle issue plz help!!!
wats the year.. make.. model?
Old 04-19-2009, 03:13 AM
MD426's Avatar
Did you switch out the ECU? Maybe a bad connection with the park sensor with the auto ECU?
Old 04-19-2009, 01:29 PM
New User
Icon3 Re: Idle issue plz help!!!
Acura Integra 1996 RS that was auto stick and now with a manual tranny from an LS and 1998 ECU
Old 04-19-2009, 05:25 PM
bfatdaintegra's Avatar
thats puzzeling i dont know why that would do that unless theres a vaccum line that went to the auto trans thats sitting there not hooked up un should see if it has one and plug it if it does
Old 04-20-2009, 03:56 PM
New User
I'm searching right now for a 96 ecu
Old 04-22-2009, 09:38 AM
jrthestar's Avatar
my car is a 94 ls with a obd1 ecu and 95 ls tranny i tryed changing the map sensor and i changed out the ecu and it kept on.. i did try a pr3 or pr4 one of the two which is an obd1 ecu and it stopped but then my idle was very low and wen i would stall out it would take forever to restart.!!!!!
Old 04-23-2009, 03:40 PM
jrthestar's Avatar
b u m pppppppppppppppppp
Old 04-23-2009, 05:58 PM
matsgsr's Avatar
check to see if your tps sensor is working properly. It should read somewhere between .45 and .5v at WOT
Old 05-15-2009, 08:36 PM
New User
1996 Integra RS
projectTeG
12-20-2005 04:23 PM
majek
07-17-2005 05:10 AM
juka
10-18-2004 06:36 AM
wpgcivic
05-27-2004 04:47 AM
Quick Reply: Idle issue plz help!!!
