how to replace pistons
Old Oct 26, 2002 | 07:37 AM
sshaikh01's Avatar
Default how to replace pistons
Is there a site which explains how to do this.
Do i have to take the block out of the engine bay?
I need to replace the pistons/rods. forged internals
Old Oct 26, 2002 | 07:41 AM
sshaikh01's Avatar
Default Re: how to replace pistons (sshaikh01)
whats a girdle ??
Old Oct 26, 2002 | 08:04 AM
Vertigo's Avatar
You can change your pistons while your block is still in your car. Jack the car, pull the head off, take the drain pan off. Make sure you have a set of torque wrenches around.
Old Oct 26, 2002 | 11:13 AM
sshaikh01's Avatar
whats a girdle ??
come on honda-tech where are you
Old Oct 26, 2002 | 04:16 PM
sshaikh01's Avatar
come one people
Old Oct 26, 2002 | 05:09 PM
jdmotorsports's Avatar
Default Re: how to replace pistons (Transition)
a girdle supports the botton of the block. it links the cylinders toghter to add strength. good investment if your going big HP. but if you dont have a gs-r you'll have to swap certain parts.
Old Oct 26, 2002 | 05:31 PM
Rtzx9r's Avatar
GDD 1%
NO offense, but if you do not know this basic trivia, I would advise against replacing pistons/rods, as I am sure you do not know of capping the studs on the rods/etc and are going to create trouble for yourself.
Old Oct 26, 2002 | 07:05 PM
IC x Prince's Avatar
New User
Default Re: how to replace pistons (Rtzx9r)
yeah go to a shop...but you have go from under the car and depending on how the cylinder walls look, yuo might need machine work. but basically, from under the oil pan...or remove the oil pan.
Old Oct 27, 2002 | 04:21 AM
sshaikh01's Avatar
I've done two engine swaps.
Just done replacing a new head gasket on a 94 civic. (all alone)
and replaced an oil pan, and tranny on a 92 integra.
I'm capable of working on my car, its just that i never touched the block, and i'm planing on doing a swap.
Old Oct 27, 2002 | 06:36 AM
erikgsr's Avatar
New User
Well are you changing just the pistions? or you are rebuilding the motor?
If you are rebulding for perfromance, you might wanna b@b and get the motor clayed to check for clearance, that pretty hard to do it yourself, if you have never done it.
erik
Old Oct 27, 2002 | 09:33 AM
sshaikh01's Avatar
Default Re: how to replace pistons (erikgsr)
Actually i'm building myself a ls/vtec i don't want to bore the block.
I'm just going with different pistions and rods.
eg4life1202
10
Dec 1, 2018 11:05 PM
TravisBiggie
May 25, 2012 05:04 AM
cluelessmale
May 28, 2007 07:43 PM
teal_dx
Jan 27, 2006 02:34 PM
