GSR swap in to LS (Please look)
Hey guys, just did some searching but nothing final on my question. I need a quick answer for this one. I wanted to know if a 98 GSR complete engine will fit a 94 LS? It should bolt right in but im not sure about the wires. The engine comes with ecu and wiring harnes from a 98. Complete bolt in or no? Im gonna be inst. this to someones car. Any response is apreciated.
Ooo! This is a toughy. It is very possible to turn your car into an OBD2. But the wiring is a biznitch!
Any good competent speed shop can get the wiring done for a good price. But check this thread on Team-Integra I posted a while back. It talks about what you need to have to switch engines and what is "nice" to have.
http://www.team-integra.net/fo...earch
Re: (fullracegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullracegsr »</TD></TR><TR><TD CLASS="quote">engine drops in... all you need is gsr throttle cable and wire vtec solenoid, pressure switch, and knock sensor... not hard at all...</TD></TR></TABLE>
Oh and a obd2 to obd1 harness would help...
Re: (EL Vap133)
this is not a civic... obd2 and obd1 engine harnesses plug right into each other... as long as he has an obd1 ecu he wont need a conversion harness...
integra engine harness seperates at the shock towers... not at the ecu like civics do!
Re: (GS-Rcivic)
have fun, the GSR is not worth the extra cash, use the money and turbo your LS engine..
A friend of mine did the swap, and he's only runnin 14.9.. I run 15.2 with AEM CAI, Tanabe Exaust and 5Zigen header in my LS..
Re: (Chunks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chunks »</TD></TR><TR><TD CLASS="quote">have fun, the GSR is not worth the extra cash, use the money and turbo your LS engine.. </TD></TR></TABLE>
until you put a turbo on a gsr...then the gsr is well worth it...
hon da top
08-23-2007 06:56 PM
