Fuel Cut-Off Switch Problem
Old May 15, 2005 | 11:01 AM
r3v da t3g's Avatar
Default Fuel Cut-Off Switch Problem
I have the Kill Switch for about a month and today when I started the car I heard a noise sounded like it was shocking something and then my car died. I cant start it back up, could I have short circuited something? NEED HELP ASAP!!!! Thanks In Advance
Old May 15, 2005 | 11:17 AM
WhiteGSR95's Avatar
probably fucked something up, u should check all the wires for the kill switch. something probably fried
Old May 15, 2005 | 11:19 AM
r3v da t3g's Avatar
Default Re: Fuel Cut-Off Switch Problem (r3v da t3g)
heres what I just did, i took the switch off and just hooked up str8 wires and it still wont start. Chould i check the fuses? or could i hace fucked up my fuel pump itself. Im in need of HELP cuhz i gotta go somewhere
Old May 15, 2005 | 11:23 AM
WhiteGSR95's Avatar
well at 1st i was thinking that the fuel pump wires might have fried. check the fuses.
Old May 15, 2005 | 11:27 AM
r3v da t3g's Avatar
Default Re: (WhiteGSR95)
I checked the fuse and found that i fried the fuse, thank god it was only the fuse. I'm going to have to electric tape the switch so this wont happen again. Good thing i got tons of fuses, Thanks alot for the quick reply WhiteGSR95.
Old May 15, 2005 | 11:38 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: (r3v da t3g)
you should periodically check your soldering, because since the pump's under the rear set it may come loose after people sit on it on and off for a while. happened to me.
Old May 15, 2005 | 12:20 PM
WhiteGSR95's Avatar
glad to b of assistance. fix that switch because chances r that it will happen again.
FTNW
28
Jun 7, 2011 04:59 AM
swiftjdmzc
11
Jan 17, 2008 05:30 PM
x_tuh_sy
Dec 19, 2007 02:49 PM
92integraVTECgsr
Audio / Security / Video
Oct 10, 2005 09:14 PM
kKdARIAN
16
Dec 16, 2002 09:06 AM
