Fuel Cut-off Switch Nightmare
Vice President/CEO
Ok. Today I tried to install the fuel cutoff switch on my car. Well.. something went terribly wrong. I spliced the green/yellow wire and did the wiring on it. Well something went wrong cus when i flipped the switch to "off" the car turned off.. and never turned on again. I undid all the wiring i had done, and still no response. The car SOUNDS like it wants to start, but does not. It seems like no fuel is going through. I have no clue what to do.. My car is currently dead.. any help would be greatly appreciated.
a sad and somber,
kENNy
a sad and somber,
kENNy
Re: Fuel Cut-off Switch Nightmare (kKdARIAN)
If i were you id check your fuses first. If anything else try reseting your computer by disconecting your neg. battery terminal for a few minutes and see what happens. Its probably a fuse though..
let me know what happens....PM me.
Vice President/CEO
Re: Fuel Cut-off Switch Nightmare (Kamin)
I took all the wires off, no more switch.. just the same old setup as it was. I have not tried to listen for the fuel pump to prime, what should it sound like? (stupid question?)
Vice President/CEO
Re: Fuel Cut-off Switch Nightmare (TheRedSkoolingBus)
I have checked all my fuses, all are fine, including the ones under the hood. I will try the computer reset right now.
garunteed *sp? that you blew the fuel pump fuse.. its under the dash, next to the yellow abs fuse..
i dont understand why everyone makes a cut off switch it does work but you can also pull the fuse, and put in a blown one and a theft will enver know the difference, all you gotta do is take out all the spare fuses so he doesnt have a fuse to put in there.. although he could take a p/w fuse or something i guess.. check your fuse bro, you blew it..
Turn your key so the accesory comes on. Listen for a buzzing noise under the back seats. Also turn your radio off. If you hear the buzzing then the fuel pump is coming on. If not, then it isn't.
Re: Fuel Cut-off Switch Nightmare (Vanilla4215)
damn all these replays in that little time.. are you sure you check the right fuse? im not callin you out or anything but my roomate once over looked it and was scared as hell like you were..
Vice President/CEO
Re: Fuel Cut-off Switch Nightmare (95CivicEX)
*SIGH*
holy sh*T i could have sworn i went through all the fuses... it WAS blown.
that was it. Thank you sooo much for all the help. That was totally fast and saved me the $$ to have the car towed to a shop and for them to charge me $200 to tell me it was a fuse.. Thank alot... everyone.
kENNy
kENNy
Damn did i call it or what?!!!
Okay Im going to PM you my address so you can Mail me my $200.00 dollar check y0!
Vice President/CEO
lol. that totally rocks dood.. yes you did nail it. i guess i failed to mention that i was not gonna have the money to get it fixed till sometime next year... damn holidays and overspending... sheesh.. There will be a special page on my props page for ya..
kENNy
kENNy
nice to finally read a thread where everything works out, and everyone is so nice to each other. i been hanging out in kills stories way too long. haha i keep thinking everyone is out to get each other.....all the flames...
Re: Fuel Cut-off Switch Nightmare (slowasscx)
So what wire did you use? the one under the rear seat? or under the dash? what color?
EDIT: ohh ya...whyd the fuse blow?
[Modified by ragejed, 9:32 AM 12/16/2002]
