How to Torque Down Crank?
Old Jan 2, 2004 | 02:15 PM
LudeyKrus's Avatar
Default How to Torque Down Crank?
What's the easiest way to torque down a crank that's in a longblock that's sittin on a bench? Tryin to do this w/o turning the whole bottom end when I pull....
Old Jan 2, 2004 | 02:56 PM
BeerMan's Avatar
Default Re: How to Torque Down Crank? (LudeyKrus)
you got a second set of hands to help you? If not, I would wedge it against something, so it doesn't twist when you twist
Old Jan 2, 2004 | 06:43 PM
mmuller's Avatar
Mad Scientist
Default Re: How to Torque Down Crank? (BeerMan)
i'm assuming you mean the crank pulley bolt, i put the flywheel in and wedge it or tie it against where the tranny bolt goes
Old Jan 2, 2004 | 07:01 PM
LudeyKrus's Avatar
I meant when tryin to torque down the pulley bolt and the flywheel bolts.
Old Jan 2, 2004 | 07:06 PM
mmuller's Avatar
Mad Scientist
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I meant when tryin to torque down the pulley bolt and the flywheel bolts.
pulley, well you know already; flywheel bolts ill do the same..i usually usu one of the holes for the clutch bolt and tranny bolt and tie them together.
Old Jan 3, 2004 | 03:02 PM
Boofster's Avatar
Default Re: (mmuller)
I'm not sure if the stock plate and flywheel have the holes but my ACT combo had extra screw holes that weren't used. I put in an allen wrench that fit snug and lodged it in the block groove so it sticks. You can torque all the clutch parts like this and also the crank bolt at 130 ft/lbs.
Old Jan 3, 2004 | 05:09 PM
thad
Guest
Posts: n/a
Default Re: (Boofster)
the best way i've found is to take out one of the clutch bolts on the flywheel and stick a 1/4" drill bit through it (the flywheel) then back the crank up till it's locked against the bellhousing, then you're free to torque.
Old Jan 3, 2004 | 05:56 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
pulley, well you know already; flywheel bolts ill do the same..i usually usu one of the holes for the clutch bolt and tranny bolt and tie them together.</TD></TR></TABLE>
i usually do something similar to this but i use a wrench and 2 bolts..one end has the tranny bolt the other has the PP/clutch bolt on the flywheel..works for me..
drifterX420
Jan 1, 2008 10:45 AM
HondAcura
Dec 24, 2005 05:24 AM
88 dx
13
Aug 19, 2005 10:30 AM
Blueallie
Jan 2, 2005 02:47 PM
baonest1
Nov 19, 2002 12:37 PM
