engine is staying a solid 2500 when warm
Old Apr 10, 2004 | 10:50 AM
.cingham's Avatar
Default engine is staying a solid 2500 when warm
I've followed all the vacum lines, everything is right.
Wired to have the fan run constantly.
what should i check next the ivac?
Old Apr 10, 2004 | 11:24 AM
.cingham's Avatar
Default Re: engine is staying a solid 2500 when warm (cingham)
no codes either...reset the ecu too
Old Apr 10, 2004 | 11:26 AM
94gsr4dr's Avatar
Have you tried to just adjust the idle? Sorry to state the obvious
Old Apr 10, 2004 | 04:02 PM
.cingham's Avatar
you never touch the idle screw...if you do you get screwed i've learned that in the past.
Old Apr 10, 2004 | 04:19 PM
ZoominTeg's Avatar
Default Re: (cingham)
Follow the directions in a repair manual and u'll be fine bud.
Old Apr 10, 2004 | 04:55 PM
.cingham's Avatar
yet no codes, vacum lines are secure and correct....going to try the ivac tonight
Old Apr 10, 2004 | 05:01 PM
kablamo's Avatar
might seem too obvious, but have you checked the throttle cable/throttle assembly? if something is seized or not letting the slack off completely, that would explain it not going below 2500rpm..
doesn't hurt to check the basics before taking the whole damn thing apart
Old Apr 10, 2004 | 06:55 PM
ZoominTeg's Avatar
Default Re: (kablamo)
Good point Dude, btw, u keep mentioning vacuum lines. What would idle have to do with vacuum lines, just a question, and i seriosuyl want to kno the answer :0.
Old Apr 10, 2004 | 07:09 PM
G1 TEGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cingham &raquo;</TD></TR><TR><TD CLASS="quote">you never touch the idle screw...if you do you get screwed i've learned that in the past. </TD></TR></TABLE>
yeah i don't think whatever screwed you over in the past was an idle screw
Old Apr 10, 2004 | 07:22 PM
teggy1000's Avatar
Check to make sure there's no air in your cooling system. 2500 sounds too high for this condition, but if you have air bubbles in your cooling system, the temp. sensor will detect cold if there's no hot water touching it. It will then keep your idle elevated. Other than that you might have an air leak someplace or a stuck throttle plate.
Old Apr 10, 2004 | 07:44 PM
riceball777's Avatar
why d ont u just adjust the idel
Old Apr 10, 2004 | 07:58 PM
.cingham's Avatar
k, folks...this is why you don't adjust that idle screw...i know you'd probably love to do that, but you know what if the car was tuned for that and its reving that high...then there is no need. Your not fixing the problem, your causing another.
Old Apr 10, 2004 | 08:38 PM
garlic jr's Avatar
^no, sometimes that screw gets loose or out of place in time for whatever reason. theirs no harm or foul in adjusting it to the right spec that it came out of the factory, thats your own mis conception.
Old Apr 10, 2004 | 08:55 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (garlic jr)
Try this article or the archived articles on Hondaswap.com: Eratic idle problem.
http://www.hondaswap.com/forum...29790
Might not be exactly what your prob is but it may help. I emailed the author of the article and he was very willing to help. So you may want to ask him about your problem.
haroldthefly91crx
Mar 31, 2007 02:09 PM
1baddturbosi
Mar 17, 2007 09:17 AM
DA9teg93
May 9, 2005 12:12 PM
Civichatch27
12
Oct 4, 2004 01:11 PM
wu tang
Jul 25, 2003 11:58 PM
