Engine noise after changing timing belt....
Old 12-27-2005, 08:10 PM
JDMoMo
Guest
Posts: n/a
Default Engine noise after changing timing belt....
Hey guys...yesterday my timing belt broke and right when it broke, I heard a noise, sounded like a siren....so today I put the new timing belt on and the noise is constant when the engine is on. I'm not sure if it's from the new timing belt, because it's new and neets to set in? But I'm taking a trip tomorrow and will be driving about 3500 miles so can someone tell me if it's safe? Is it supposed to make noise right after changing the timing belt? Do I need to break it in?? Thanx
Old 12-27-2005, 08:44 PM
CNSK's Avatar
Default Re: Engine noise after changing timing belt.... (JDMoMo)
theres no such thing as break in timing belt.......either you did it correctly or not....since you said you crank the engine 15 times or so with a snap timing belt, there could be possible valve damage. Also check and see if you tighten all your ps, ac, and alternator belt down....loose belt can make those noise.....did you shoot your timing with a timing gun after installation to make sure its right on the dot?
Old 12-27-2005, 08:54 PM
Sinner's Avatar
maybe your other belts are loose
Old 12-28-2005, 03:14 AM
JDMoMo
Guest
Posts: n/a
Default Re: Engine noise after changing timing belt.... (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">theres no such thing as break in timing belt.......either you did it correctly or not....since you said you crank the engine 15 times or so with a snap timing belt, there could be possible valve damage. Also check and see if you tighten all your ps, ac, and alternator belt down....loose belt can make those noise.....did you shoot your timing with a timing gun after installation to make sure its right on the dot?</TD></TR></TABLE>
no I didnt shott the belt w/ timing gun.....is that something that has to be done?
Old 12-28-2005, 06:06 AM
TurdBlown Teg's Avatar
not if you took the belt off but since you didnt its going to be a bitch to do with out one
Old 12-28-2005, 09:29 AM
JDMoMo
Guest
Posts: n/a
Default Re: (kevin716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin716 &raquo;</TD></TR><TR><TD CLASS="quote">not if you took the belt off but since you didnt its going to be a bitch to do with out one</TD></TR></TABLE>
took it off what?? im lost now
Old 12-28-2005, 11:40 AM
.water's Avatar
when timing belt snaps, were u drving hard? or normal? or after car died did you try to re-crank the engine? there are possible chances that have some bent valves. just like anyothers.
or
check everybolts you touched. if tendtion bolts are too tight or too loose it might make sound from belts.
Old 12-28-2005, 12:16 PM
JDMoMo
Guest
Posts: n/a
Default Re: Engine noise after changing timing belt.... (zzzkangzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzzkangzzz &raquo;</TD></TR><TR><TD CLASS="quote">
check everybolts you touched. if tendtion bolts are too tight or too loose it might make sound from belts. </TD></TR></TABLE>
I think that's what it is....just needs to get used to it...I'm sure after drivin 3500 miles it'll be aiight....
Old 12-28-2005, 03:59 PM
roadrunner's Avatar
If the new belt is too tight, it will make a whining sound, but that doesn't explain the sound it made before it broke. The noise you heard before it broke (sounded like a siren) and then now the sound is constant, this sounds like maybe a water pump or tensioner bearing might be giving up.
Old 12-29-2005, 04:45 PM
dont listen to me it was a drunken post
RandyOo
12-26-2013 02:35 PM
ECStarr
Honda Civic (2001 - 2005)
08-30-2012 04:44 AM
niceprelude
11-02-2008 09:54 PM
bam181
08-20-2006 05:16 AM
ka0s187
12-14-2005 12:25 PM
Quick Reply: Engine noise after changing timing belt....
