ecu codes
Old Jun 11, 2006 | 06:48 PM
95_red_dc's Avatar
Default ecu codes
yes i am throwing 3 ecu codes 1 is for the o2 sensor. camshaft positon sensor, throttle positon sensor i ahve a 91 crx with a b18b swap obd1 conversion , iwas woundering if the motor is loosing power from those three thanks, oh yea for the camshaft positon sensor would i have to get a dizzy
Old Jun 11, 2006 | 10:01 PM
ckyguy's Avatar
If it isn't in limp mode from those, it's probably not losing power so to say. The powerband definately shouldn't be as smooth however, and hence you won't be as quick even if your max hp stayed the same.
Sedwards1200
Sep 3, 2016 03:31 AM
Vash121991
Apr 12, 2012 02:51 AM
shytdoode
May 20, 2009 03:41 PM
racingant
Sep 10, 2005 05:34 PM
