2008 civic si issue
Old Aug 30, 2016 | 06:10 PM
Sedwards1200's Avatar
Default 2008 civic si issue
Alright I hope you guys can help. I lowered my car and I tore 2 of my 02 sensor wires. This sent the car into limp mode. On my way to the shop to get it fixed I lost all power to the car. I managed to get it there, barely. So we replaced the alternator because it was showing low voltage. Also replaced the o2 sensor. The car is still in limp mode and showing multiple codes. Crank sensor, maf sensor, and several others. Also the car is still losing power. Could the o2 sensor shorted the ecu and fryed it? Thanks for the help guys
Old Aug 31, 2016 | 02:02 AM
holmesnmanny's Avatar
Default Re: 2008 civic si issue
start with checking ALL fuses
Old Aug 31, 2016 | 03:14 AM
Alright I'll will check all fuses and reply. I do have a flashpro tune on it and I'm going to try to reflash it and see if resets the ecu.
Old Sep 2, 2016 | 10:05 AM
fcm's Avatar
fcm
Old Fart
Heated 02 sensors are 12V+ powered, [and fused], a short from that 12V+ to the ECU signal lead is probably not going to be good for the ECU.
My guess is the ECU is toast.
Do you have access to another ECU you can try? 94
Old Sep 2, 2016 | 10:09 AM
thats what I figured.... I am picking up an ecu and trying it in the morning
Old Sep 3, 2016 | 03:31 AM
It's not likely an ecu issue if you didn't blow any fuses.
BoostJockey
23
Feb 7, 2014 04:42 PM
chevy383
32
Jan 11, 2014 02:19 PM
b16jaf
Nov 28, 2007 12:07 PM
portfl0w
Apr 17, 2007 09:12 PM
