b16a da9 problems ecu question
Old Apr 10, 2012 | 04:29 PM
Vash121991's Avatar
Default b16a da9 problems ecu question
sup guys.,
i got a b16a in my 90 integra gs., converted 2 obd1. the ecu is a gsr ecu, but it had been chipped.
my car started bogging down in lower rpms only with no cel.
so when i was under the car i noticed there was a green plug with a broken sensor plugged into it on the back side of the block just hanging there,.
any one have an idea if a chipped ecu will hide CEL codes? cause i aint throwing anything.
Old Apr 10, 2012 | 07:35 PM
el crapitan's Avatar
Default Re: b16a da9 problems ecu question
how many pin is the sensor? could be a knock sensor
Old Apr 10, 2012 | 07:36 PM
here's an idea; unplug the sensor and see what code it throws
Old Apr 11, 2012 | 02:15 PM
str84sfed's Avatar
my jdm pr3 wont throw 02 sensor code on my b16b, is there any power gain if you do a obd1 or 2a conversion? i have a civic r ecu that came with my swap.
Old Apr 12, 2012 | 02:51 AM
the conversion itself isn't going to net any gains. it only enables you to run a different pcm and single o2 sensor.
the different pcm/tune may net you some power
shytdoode
May 20, 2009 03:41 PM
andyt
Feb 20, 2007 06:08 PM
95_red_dc
Jun 11, 2006 10:01 PM
InEK
20
Apr 10, 2006 09:03 PM
rainmanef
Jun 13, 2004 10:29 PM
