Dizzy o ring replacing problem
Old Mar 30, 2009 | 06:04 PM
danielblushtein's Avatar
Default Dizzy o ring replacing problem
I want to change out the o ring on my distributor(or how they call it "dizzy"). will I screw up the timing or what are the things I have to be aware of?
THANKS GUYS
Old Mar 30, 2009 | 10:03 PM
Default Re: Dizzy o ring replacing problem
anything???
anyone change it???
Old Mar 30, 2009 | 11:24 PM
HeikDiesel's Avatar
Just use a sharp object to scribe a line from the head to the dizzy. It should keep your timing close. Good luck
Old Mar 31, 2009 | 05:41 AM
tylersvols's Avatar
yeah just make you some marks where it bolts up then just pull it off and fix it and put it back on according to your original marks. and when you go to start it and if it doesn't start your distributor is probably 180 out.
Old Mar 31, 2009 | 02:19 PM
what do you mean 180 out???
Old Mar 31, 2009 | 03:37 PM
HeikDiesel's Avatar
Well you really can't install it 180 degrees out of timing because the slits are offset. The distributor has a male slit and the cam has a female slit. That is how the distributor is driven when they are in mesh
Old Mar 31, 2009 | 04:50 PM
tylersvols's Avatar
Yes you can. I've done it before. i had to buy a new dizzy and when i installed it the timing was out 180 so i took the dizzy of and turned it 180 and problem solved.
Old Apr 1, 2009 | 10:24 AM
HeikDiesel's Avatar
If you pull it off the tangs are offset. If you put it 180* off it should have been very obvious when you tried to push the distributor in the hole
Old Apr 1, 2009 | 11:08 AM
AlphaQup's Avatar
That's how he f**ked up his original dizzy. It'll fit "forced in".
Old Apr 1, 2009 | 11:33 AM
tylersvols's Avatar
Forced in? yeah right it slid right in i didn't even have to try. my original one the shaft in it had a grove in it and one of the seals was bad and it put oil in my dizzy so i replaced it.
Old Nov 29, 2011 | 10:46 PM
koreboy's Avatar
Yeah marking the base of the distributor (at the centre top bolt) along to where it's connected to the engine is very important to keep timing. I as well used a ruler and sharp metal object to make the mark. I also found that it also helps, before removing the distributor, to take the cap off as well so one can see the position of the rotor (another reference point), so just incase if it is accidently rotated one generally knows the position that it should be in, and this will help to place the distributor back into its slot!
Old Nov 29, 2011 | 11:03 PM
Dc4LsTeG's Avatar
EK9
Edit: Srry didn't realize guy above me bumped an old thread
jakscivic
Jun 2, 2010 07:29 PM
freshly boosted DOHC ZC
Jul 26, 2007 01:47 PM
bayoufrogg
Jul 27, 2005 11:17 AM
Hybrid Invasion
Mar 31, 2003 02:35 PM
Pele
Nov 30, 2002 01:04 AM
